Hello, just rebuilding a US import that was part complete, and noticed the frame is different from all of the other pictures I have looked at - only noticed this when it came to hanging the silencers!
Where the small lug for rear pegs and silencer bracket is normally located I have looped frame tubular. I will work around this but was just curious if this was a frame variant or just a mod someone did. The frame is stamped up and matches engine number - Steve
I've never seen that loop…
I've never seen that loop before. But there is also a mysterious boss at the bottom of the main frame loop. In my pictures, that corner is always behind the silencer, but it certainly wasn't on later frames.
I wonder if someone used it for sidecar racing, and the loop was added as a hand grip? The only time I rode on a flat sidecar I had to hang on to a fan belt attached to the frame.
It's on the right, where (I guess) a sidecar might have been fitted in the USA, possibly with siamesed pipes on the other side (not UK side), so there was no need for exhaust pipe hanger? Did it come with an exhaust fitted?
88 Frame
Hi there, it had exhausts fitted (not siamese) but no silencers - and the frame loop is on both sides.
The boss at the bottom of the frame, that is on both sides too with through tubular in between. I have never had a dominator before so didn't really think about it when I stripped it down.
Sidecar mount is a good call, but nothing looks amiss at the steering head or down tubes - I think they would have bodged a bracket there as well.
Here it is as I received it.
Strange Frames
This frame is most likely a 1955 or 1956 version of the Featherbed. So with a non bolt-up type of frame. It has the wide top rear loop of the Manx and International frames which accounts for the shaped oil tank.
The earlier bolt-up frame had a droopy rear sub-frame loop that supported the rear mudguard. Whereas the 1955 on welded frame rear ends stopped short by the suspension units.
Clearly this frame has received a few serious modifications for what ever purpose.
The triangular rear passenger footpeg plate has been replaced by a piece of piping / tubing that just looks completely wrong.
The top of the rear frame should stop around 4” after the rear suspension top bolt. This frame has been extended with some heavy duty pipe-work to emulate an earlier bolt-up version.
The factory has never really explained the strange chunk of cross-tubing at the bottom rear section of the Featherbed frame. The best suggestion being to add strength to that frame section in the event of a side-car being attached. Though, for the rest of the 1950s, Bracebridge always claimed that the frame was not designed for use with a sidecar.
Nice colour
Nice colour!! Or should I say color? The idea of hanging onto that loop while 'in combat' in the chair, with the rear wheel that close!! No thanks.........
Looks great!
Hi Steve, your Wideline 88 looks stunning in the early shade of Polychromatic Grey - my favourite of all the Featherbed paint schemes! I'd love to see any more photos of it nearing completion - perhaps we'll see it in Roadholder?
Many thanks
Ran
Police?
The modification to the rear subframe suggests to me that rear loads were expected. Got me wondering if loaded panniers or crash bars needed a sound fixing on extended pillion loops like yours. Is this a police bike?
My own craven panniers, remarkably heavy when fully loaded, absolutely require good support near the bottom to prevent swing about the two upper rail fixings.
Frame
Peter - could be a pannier mod, I didn't know the US police used Nortons. Maybe owned by a guy who toured with it, but the welding on the loops is very good, much better than the rear frame.repair.
Ran, I should finish it in a couple of weeks, I'll post a picture.
Steve
Stunning!
Steve you've done a lovely job, it's a credit to you. Can I ask how you got the correct shade of early Polychromatic Grey? Did you use VW Platinum LD7X?
I'll make a note of the colour type etc for when I find a '54 88 Domi, hoping to get one when I sell my '72 Commando.
wow ! ,what a lovely job. A…
wow ! ,what a lovely job. A very individualistic looking machine. The only line I would question is the battery that appears to lean backwards . And its clear what those loopy things are for , somewhere to hang the brake switch !!. Some Dommies have the appearance of engine etc lolling backwards too (a bit sad looking) , you have avoided that somehow , Longer than std rear suspension units ?. I can see a few prizes comming.
Battery box
Thanks, its been in bits for years - and I am trying to clear my feet of 'projects'. I am starting a Ducati 860 next, its also been in pieces for a long time.
The battery box is rubber, so when I tighten the strap it goes a bit wonky - will swap it for a hard case at some point. Once its off the ramp it might sit differently - I'll know this weekend. I am just waiting on some petrol pipe to hook up the carb before I fit the tank strap in case of leaks - but it is oil tight so far!
Good Work
Steve.........great restoration. Looks good all over. Well done.
My records indicate two batches of modified Model 88s sent overseas (poss USA) in Police trim. One batch of three in Jan 1955 and a second in Feb 1955. Could your Norton be one of these? Have you got a frame number that you would be willing to share?
Hi Steve ,perhaps we will…
Hi Steve ,perhaps we will confer over the 860 restoration , I have had one lurking for years , Space being the big issue . And now I have now somehow aquired a 650SS proddy racer project .
A strange thing about the…
A strange thing about the loops is that, if they were designed to provide a fixing point for panniers, footrests, silencer etc, there is a complete absence of any drilled lugs, brazed onto the loops, through which to fix them. They may have been cut off at some point in its life, of course, but too late, now that it has been painted, to look for any tell-tale signs of such.
Police 'bikes would not have had pillion footrests of course, so Peter & Phil may be onto something there.
frame
I should have noticed it was wrong before I got it painted - I would have welded on lugs for the silencers.
The brackets I made for the silencers are bit clumsy but they will do. I have a couple of struts off a set of Raygun silencers from a Rocket 3 and even contemplated using them! I'll leave that plan on the drawing board for now.
Details suggest 1955 or 6
It has the exposed battery, bolt-on rear mudguard section and round footrest rubbers. That suggests a transition between 1955 and '56 spec.
I like the early '50s polychromatic blue better than any poly grey, but then I may be biased -I have one of those.
Despite the DSN and its conception I have never heard or seen of such a frame! Interesting points here is that the plate at the top of the rear damper unit has been refitted ie poor weld, but the foot rest/silencer loop looks very original fitting. The seat loop is also different, slightly up swept by the tool tray and the continuous loop over the mud guard is new to me. But we all have to remember that this frame is 70 years old! Any one with any ideas?
