Canada calling. My Model 7 laydown is installed, what is the best way to put oil the gearbox? Thanks for the help.
the clutch lifter inspection cover
Thanks for the follow up…
Thanks for the follow up. Just peeked in the clutch lifter aperture, looks like a long arduous process. I think leaning the bike over may help the process, perhaps there is wunderkind out there with a speedy solution!
All is well, funnel, tube…
All is well, funnel, tube and most important for me, putting the 7 on the side stand to create an 'angle' delivery of oil. No difficulty once I had done that. many thanks for the input.
If you're in the snowy North…
If you're in the snowy North :-) it might help to warm the oil a little before pouring in. Just stand the bottle in a container of very hot water for 5-10 minutes.
From rainy England :0
Even in the south
If you happens to have an old gearbox that uses semifluid grease, warming as Michael said makes it possible to get the grease/oil mixture into the box. Not sure but some really old Nortons might have used it.
Gearbox Goo - Pre Laydown Boxes
keep adding oil?
Whenever I check the oil level in my gearbox, there is always some oozing out of the level plug hole. I haven't been asked to add any for at least two or three thousand miles. Maybe I grossly overfilled it initially.
Phil, it never occurred to me to use sloppy grease in a Norton box. I use hypoid gear oil, but you have to make sure it's not going to eat your bronze bushes.
may be removed for filling the gearbox. It's the one with the Norton logo on it... It's a bit awkward pouring oil in from a bottle, unless it has a filling tube extension. I made a spout from a plastic bottle, using the area round the handle. There's a level plug below and to the rear of this inspection cover with a square head. Remove that, pour oil in until oil starts to flow from the hole.
