The atlas ( single carb) has been making an unusual popping in one of the exhausts on tickover. I haven't ridden it for some time. . The plug is also sooty . I changed the plug and no difference . My suspects are, an air leak into the exhaust at the head , the thread is a bit rough where the pipe flange got loose sometime last century and the nut gets tight before it fully grips the pipe. A tight exhaust tappet allowing some mixture to squeeze past into exhaust and getting lit up there. A failing (early type) Boyer that has been ignored for 20 years or so. My question is , if I swap the plug leads , will it run ?, this may transfer the issue and point to the Boyer, what do you think?.
Yes, the Boyer is a wasted…
Thanks Peter, I will tell…
Thanks Peter, I will tell all when I get to the bottom of it.
hello again Bob, It is…
hello again Bob, It is possible for the Boyer to be wired up in the conventional way with each ignition coil and pickup coil for each cylinder. It usually depends on whether your Atlas was a twin coil, with capacitor discharge system, from new. If so it would have already had the extra wiring for the individual coils, ignition switch etc. Normally if the Boyer replaced a magneto set up or single coil system with a distributor, people tend to put two 6V coils in series with a simple wiring addition. Was the Boyer fitted by a previous owner or you ? When i converted my Mercury to Boyer I kept the 12V coils and wired the pickup coils to each coil separately. Unfortunately when the coils are in position between the battery box and oil tank it's hard to tell if they are 12V or 6V as the number is stamped underneath. Like the Atlas and 650SS from 1967 a Mercury used two 12V coils. The extra current in the 6V coil will give an increased spark plug voltage but with a wasted spark a lot of the energy is wasted. The only thing wrong with the original system was the advance and retard mechanism which regularly flew apart - hence the need for the Boyer or similar. Good luck, Howard
Hi Bob, in addition to what…
Hi Bob,
in addition to what you are trying, can you check that the inlet manifold is sealing properly on all joints? Could be a small enough leak to allow air in at the offending side, but 'too far' from the other cylinder to affect it? Is compression same both sides?
Otherwise, as you suggest, tight tappets, or the exhaust seal at the head should be at the top of your work list.
Regards,
George
Popping
My B40 was popping when rolling back throttle, engine braking. Normal BSA problem with leak between head and pipe. My early flathead Harley did pop a lot when rolling back throttle and ignition at the same time, engine braking.
But you say your bike pops on idle. Sounds more like ignition to me. Worst thing that could happen swapping plug leads is that it don´t start.
Usually when you think it's an ignition problem it's a carb issue.
Yes, the Boyer is a wasted spark system. Both coils fire at the same time
