I replaced some gearbox internals and now after rebuilding I can select gears in one direction but I cannot then select ANY gears . With the outer cover removed I can select all 4 gears and there is clearance at either extreme length of travel of the quadrant. Does that mean quadrant and cam plate are correctly timed?
Now for the outer cover - yes the straight part of the gear change spring is fitted towards the top of the outer cover.
Mick Hemming say to select 2nd gear and fit outer cover ensuring the knuckle pin roller is facing outwards. In which position is the knuckle end of the quadrant in 2nd gear - is it facing towards the top of the gear box?
I hope someone can help as I don't have much hair left.
Top is top :)You can work…
Many thanks Stan, at least…
Many thanks Stan, at least you confirm I don't have to strip the box down again, except for the outer cover, as the knuckle end is aligned with the top stud.
I have fitted a new gearchange ratchet spring. How do I 'fiddle' with the spring? At the moment I have adjusted the spring so that there is only a small clearance between it and the gear change pawl. It seems to me when the gear lever is moved [and I can select gears] the spring looses contact with the pawl in the other direction. The gear change pawl is free on its post, and I have lubricated it just in case. Do I bend the spring inwards so there is even less clearance?
Thanks again Roger
Sounds like its working…
Sounds like its working perfectly. A small clearance both sides allows the pawl to move freely in both directions ,as it needs to.
As an irrelevant comment...
... it's a shame that this box is called the AMC one as it's about 90% Norton from before the AMC takeover and much of the internals date back to the early 50s if not even pre-war.
AMC bikes (Matchless and AJS) were using the horrible Burman boxes up till the mid 1950s.
Thanks Ian I didn't know…
Thanks Ian I didn't know that.
Robert, yes but it does not select gears. I have adjusted the clearance to too much to almost nothing. The rear wheel is raised so I can rotate the wheel in neutral or in a gear. As I said to Stan I can select gears in one direction, apparently no problem, but then when I try in the opposite direct the lever moves but I cannot select any gears.
Anyway thanks for all your comments.
Roger
One spring or other.
It sounds as if the pawl is only picking up in one direction. In use, I've known this be caused by a greenstick fracture of either the pawl spring or the gear lever return spring. On the Commandos, there is also a thin washer which has to sit on the correct side. It takes very little to stop this simple but ingenious mechanism from working.
The purpose of the spring is…
The purpose of the spring is to tip the pawl over so it engages with the ratchet in the direction you want it to move. "Fiddling" with it means bending the spring so that it doesn't quite touch the pawl at rest but the pawl flips as required as it comes into contact with the spring when the gear lever is operated. Ideally the pawl will sit so its tips are equidistant from the ratchet when at rest. You can do this with outer cover in your hand but it can take a couple of attempt to get 'just right', Hemmings must have gone over this in his videos.
Richard has described a…
Richard has described a couple of common issues that are not easy to spot , An almost invisible hairline part fracture of the gear lever return spring can take its power away in one direction . And the large "pen" steel washer is easily missplaced to jam the action. The two small bolts that hold the change mechanism to the cover have a small amount of tollerance that can be used . There has been some poor pattern springs sold ,I had to reject 3 out of 4 that i had accumulated.
I don't think anyone has…
I don't think anyone has mentioned this but in Mick Hemmings AMC gearbox rebuilding notes, he stresses that the hairpin spring for the ratchet pawls must be fitted the correct way round.
"Fit gearchange hairpin spring with the straight leg uppermost (pic 61). If you fit this the wrong way round, you won't be able to select the gears."
Top is top :)
You can work this out from how the gear lever moves the pawl - lift the lever up and the pawl moves down. To put in 2nd, use a screwdriver to move the roller end of the quadrant down to 1st, then up thru neutral and into 2nd.
If, with the outer cover in place, you can only select gears in one direction then you need to fiddle with the gearchange ratchet spring - which will be covered by Mick somewhere.
The camplate is correctly timed when the quadrant arm is aligned with a gearbox stud in 4th - again Mick will have covered this, it's also in the workshop and Haynes manuals.
