Wipac Switch Base Connections
Evening all,
Anyone know how, or if you can re-pin/wire theses Wipac switch bases. Rewiring my ‘66 Jubilee.
I do not know if the sockets are available as an accessory. But they have turned up on remade wiring looms. But I have not seen any decent sockets yet. Quite bad/poor reproductions. When ever I have been involved with a rewire with these switches I have advised to solder short lengths of wire (correct colour) direct to the switch pins (they are brass so very easy solder and heat shrink) with bullets on the ends. I can do this for you if unsure. Some details on  aoservices.co.uk  click on the orange. icon.
Thanks Alan, that great info, will check out your site.
