Looking for the thread size of the front wheel spindle, I can read here and there UNF 9/16 18 TPI and UNF 9/16 20 TPI. Which one is the good one on a 1974 Commando?
9/16 UNF is 18 tpi 9/16 x…
The Correct Axle
Most Commandos had front and rear axles with UNF threads. This should also apply to the stub axle on those machines with drum rear brakes.
Good news and great thanks…
Good news and great thanks to both of you.
9/16 UNF is 18 tpi 9/16 x 20 is cycle thread (earlier machines)
