Magneto End Cap
I had a feeling the  autoadvance unit was sticking on the Domminator's magneto. It kicked back a few times if the starting kick was a bit half hearted. Now, as I have a new CoCrMo knee fitted just 3 months ago, its important to me it starts easily and doesn't give my leg a hard time. Hence I've had the AAU off, cleaned,  lubed, with  new springs  and now back on the  bike and timed.
The problem is 1) there was just one screw holding on the  end cap and 2) that screw escaped as I put the cap back on and is somewhere invisibly stuck in the  engine plates refusing to fall to the floor (or it it has hit the floor, the garage fairies have spirited it away and will return in in a few weeks)
Obviously I need at least one new screw  so the question is what thread is that or does anyone have a part number.
Pete Sykes
... I should add the cover is one of the cut out ones  with connection to a kill button and a oil tap switch - it attaches  with 2 screws, so its not the clip on or screw on cover.
Pete Sykes
