Hi, Is there anywhere I could buy a composite head gasket for a Dominator 99 with spigoted barrels? Can't seem to seal it with the copper one.
Is there an underlying problem?
Hi Jon, The problem is the…
Hi Jon, The problem is the flatness of the barrels. I normally lap the faces, but being spigoted I can't. The head is lapped flat. I just find it illogical to use a copper gasket on surface that is not perfectly flat, a composite would be fine.
Head gasket woes
Hi Gary, I too had this same problem with the flatness of the barrels inbetween the spigots allowing blow by. Took me a long time to sort it.
Have a look at this thread - you can ignore the latter posts as it does get a bit tedious once Anna gets involved.
Hi Bob, I spent an hour or…
Hi Bob, I spent an hour or so filing high spots with a fine file, checking with a straight edge & a .001" feeler. I am getting somewhere. There was dips between the cylinders & elsewhere, also some original machining a bit rough. I wish I could find a composite gasket. The only one I can find at the moment is in a full gasket set from Feked.
NOS gasket sets come up…
NOS gasket sets come up regularly on E bay. Avoid anything from India. Its worth finding a decent composite gasket . My 99 has not been disturbed for 25 years or more. Yes there sometimes is a small seep of oil but I think its from stud holes that allow oil down the threads .
Thanks Robert, Just ordered…
Thanks Robert, Just ordered an old Payen Decoke set from Ebay.
Is there an issue with the components that needs addressing or are your procedures causing the issue?
Just some ideas to go over if you can’t source what you are looking for. Where is the leak on the joint (using the clock with 12 being dead ahead?). I take it we are not talking about increased compression ratios?
cheers
