How many different tank capacities were fitted to the slimline twins.. I make it 3.
Tank Capacities?
The std dommy tank ( 2…
The std dommy tank ( 2 versions with the filler on oposite sides ),plus the Manxman and a smaller manxman type tank fitted further back on the frame leaving the front downtubes visible ., Looking at a picture of one now. Does that make 4 !!! OH , plus the police one. 5 ??
Tank Types
The 1961 Manxman and 1962 Mk 1 Atlas had the 'pea-nut' style of tank. The US adverts state a 2 1/2 gallon capacity but that could be US measures.
The Brits got two versions for their Slimline frames. These being made by two separate companies. The difference can be spotted at the front end of the tank with one type having a more rounded nose. These tanks allegedly differ by 1/4 gallon in capacity. The Norton ads all claim that all have a 3 5/8 gallon capacity. Adding to this mix is the 77,88 & 99 tanks with a left side filler caps and the 650 and 750 tanks with right side filler caps.
The Mercury bikes had the 650 / 750 style of tank. All being the same 3 5/8 gallon capacity.
I will have to give you my…
I will have to give you my picture of the two westerner style bikes with Manxman type tanks ., one is clearly a couple of inches shorter and has a lower profile., its possible that someone has made a replacement of course. I think Anthony has better images of the bikes. Interesting about the 2 different manufacturers front curve , I have seen this but thought it was too much filler. If the tank in your picture is" correct" then there is a larger version somewhere! .
Grammar Nazis
"Orriginality" originally only had one "r" :-)
Does the Dommiracer count as a slimline twin, by the way ?
Hi Richard, Domiracer only…
Hi Richard, Domiracer only has one "m"
(Is there a tongue in cheek smiley?)
Hi Robert,
I'd include the singles in this. (Slimline 61-63 ish)
I can still only think of 1, unless you include the manxman of the factory fitted tanks.
I'd be interested, like all things Norton, to know what your other one was?
