I know this question may have been asked before but I cannot seem to find the answer. Does anyone have a picture of the inner primary chain case for a swingarm Model 7 1954 or advice on how I can source the correct one?
Many thanks
Model 7 clutch cases
The photo shown in Phil's reply are from a single i.e. ES2. The Model 7 has a larger hole to fit onto the twin's crankcase. You can see the case in the attached photo.
Philip Ham
Inner primary chainguard
Attached is a photo of the only inner primary case I've found to fit prefeatherbed Dominators. Note the bent bracket at the top to fit the hole in the engine plate. As the rear chainguard is independently bolted to the swinging arm, the inner case doesn't need the more usual horizontal bracket at the rear where the rear chainguard bolts on to on rigid and plunger frames.
Check out the attachment.
I believe that these are from a Model 7.
They appear to match the diagram in the Model 7 Parts List Book. 1949 to 1954.
