Hi members .. I have a 69 Mercury basket case with matching frame and engine numbers and the inner gearbox case has the same number stamped on it. Is it unusual to see matching number displayed on the inner gearbox case? See attached photos showing matching numbers. If anyone can throw some light on this for me, it would be much appreciated.
Regards Denis
Well it likely wasn't …
Thanks Niall
Thanks Niall
After 128646 the P11A Ranger…
After 128646 the P11A Ranger 750 series all had matching engine, frame and gearbox numbers. All my own P11A Ranger 750 bikes have a matching number stamped on the gearbox. After that gearbox number there is a letter M stamped. The letter N on the Mercury gearbox would denote it was meant of a Norton model.
Thanks Anthony
Thanks Anthony
Well Travelled Mercury
This Mercury was in a batch of three that got exported to Australia in October 1968. Not many others being shipped off before this date. If it is back in the UK now then, it has probably travelled more miles by sea than covered on the roads.
As the Mercury was built around the same time as the early Commando bikes the respective models shared a good many components but each being modified to suit. So crankcases, cylinder heads, Timing Covers etc. The gear box shells and contents were similar but using different mainshafts. The Commando boxes had the numbers stamped across the top mounting lug. See photo.
Thanks again Phil
Thanks again Phil
Well it likely wasn't factory done as clearly a different set of punches were used, quite antiquated ones by the look of it, perhaps somebody didn't want bits of different bikes getting mixed up, I have also seen people's initials, birthdays etc marked up as a form of theft deterrent.
