Ammeter or oil pressure gauge for petrol tank?
Hi all,
My petrol tank has a hinged butterfly close petrol cap on the right hand side of my petrol tank, but, on the opposite side of the tank to the fuel cap there is a hole, what I need to know is what is fitted there, an ammeter or an oil preasure gauge.
Once I have an idea of what is fitted, does anyone have any fitting details of what is to be fitted.
I'm very new to Norton's, mostly BSA, Panther, AJS/Matchless & Triumph's, this being my 1st one, back to British at 65, last time I had a Brit bike was 1978, so now not using metric, but whitworth.
Any help most welcome and appreciated.
Alan
Hi Alan,
You don't mention what model the bike is. If it is an early Model 7 there was an oil pressure gauge fitted into the left side hole on the top of the petrol tank from 1949 -1952
Originally a 0-160psi. Eureka gauge made by Tomey.
If you have a Model 7,  the drive side crankcase will be stamped with a 12 prior to the engine no.
I can send a photo of how to mount the gauge if required.
In reply to by ian_richtsteig
Hello Ian,
Thank you for your reply, after checking my engine number there is no number 12 forwards of the stamped engine number.
My motorcycle is a 1953 Model 7 Dominator, the model between plunger and feathered frames.
I assume that Norton used a mixture of parts on model changes, finishing of stock from prior models on new ones until old stock was exhausted.
A photo of the oil pressure gauge mounting and any other information would be very helpful at this stage.
Many thanks
Alan.
I saw an oil pressure gauge on one of the early Model 7 bikes, and was surprised that it read to 160lb. So how high does it go on start-up? What is the regulated pressure supposed to be?
Some Commando owners (especially in the USA) seem to like fitting gauges.  They report numbers like 75 cold. But much less when hot. Norton famously removed the gauge when panicked owners reported close to zero at high revs when hot, when centrifugal effects in the crank caused more suction than the oil delivery pressure.
Check the search function on here for others' experiences.
You'd want a generous safety margin on a gauge.
Hi Alan,
Sorry it has taken a few days to get back to you as my tank was safely stored away as it is plated and painted ready to fit. Can't be too careful.
I have removed the gauge to show the fitting arrangement.
If you want any specific measurements just let me know.
Hi Ian,
Thank you for the picture, it clearly shows the gauge & retaining fittings for me.
Now the big question, did you have to make up the fittings yourself, or where these available from some retailer?
I have to say I've not seen these fittings before, if you did not make them up, would you have any information on where to get them?
This is all new to me!
Any help would be most welcome..
Regards, Alan
Hi Alan,
Here's the measurements that will assist.
If there are any parts you want more specific detailed information on please let me know.
Ian,
Hello again, sorry to bother you again about my 500cc Model 7 Dominator, but could you please advise me as to where the take off point for the oil feed to the tank mounted oil pressure gauge is from, or is it just a (spur) take off at any convenient point close to the bottom of the petrol tank pressure gauge hole.
Many thanks.
Alan.
Hi Ian,
Many thanks for the time & effort you have made in order for me to fit the oil gauge to my tank, very much appreciated.
Regards.
Alan Thomas
Hi Alan, I've added a couple of photos to clarify the mounting of the take off unit.
The photo taken from the 1949/50 Model 7 parts book shows the set up for the mounting.
Relevant part numbers are 75, 76 & 77 and are shown just below the pressure release valve in the rear of the timing cover. The tapping is 5/16" x 22 t.p.i (BSF). The bolt used to attach the rocker feed union is the same on cast iron heads used on these early model 7's.
Several years ago you could get lengths of fine copper pipe with the 1/8" BSP union attached. I don't know if they are still available.
Any other questions just let me know.
Ian, thanks for all the great info on oil pressure gauge plumbing and take-off.
I see you indicate feed is taken at banjo bolt from below pressure release unit.
I know this is used for feed to rocker box but wondering if I need to add  a T added to the rocker box feed line with one going to pressure gauge and the other to rockers?
Have I missed something in the notes above?
Peter Cooper
Hi Peter,
For some strange reason the new website won't let me message you personally but here's some more information for you.
As Paul has described, your rocker feed is taken from the return oil line union fitted into the oiltank.
The oil pressure gauge feed  is fitted into the timing cover as previously described.
I have the original oil pump and scrolled rocker spindles fitted and get satisfactory oil feed to the rockers.
If you want to increase oil feed to the rockers use the Lightweight restrictor as Paul mentioned
Otherwise make your own by threading the return union to allow restrictors to be made from threaded rod and drill the centre of the rod to what ever the largest diameter which gives satisfactory oil feed to the rockers.
When I get home I'll post a photo of the set up on my Model 7.
Many thanks for the clarification Ian.
That will work very nicely and no don't plan to update rocker feed as it's only going to be an occasional ride not on the track.
Now I can move along and finish up the plumbing.
That tapped hole in the timing cover was used on early Model 7 machines for the oil pressure gauge, and on mid-1960s and later bikes for the pressure-fed valve rockers, which had the six-start pump drive worms. If I remember correctly, early 650 SS machines, and early Atlas had the 3-start oiling system. It is likely that the 6-start system was developed due to the demands of hot 750cc machines operating in hot climes of the USA. Early machines should not be converted to pressure fed rockers unless the lubrication system is altered to the full specification of the later oil system.  Besides the six-start pump worms and the plain rocker spindles, there are a lot of detail changes, which were done for a reason.  With those later bikes, you could fit a T-piece in the oil line so that the pressure gauge gets a feed along with the rocker spindles.
If you have an earlier bike, and feel that you are not getting enough oil to the rocker spindles, the factory recommended modification was to fit a Jubilee or Navigator oil return tank union.  This is identical to the heavyweight twin tank union, except that the drilling through the centre for the oil to pass through is slightly smaller, thus forcing more of the oil returning to the tank to go upstairs.  This modification is mentioned in PL Garratt's workshop manual of circa 1958.  Should you wish to do this mod, but do not have a lightweight twin tank union to hand, there is a solution - cut a steel disc smaller than the threads on the union, drill a suitable sized hole in it, and silver-solder to the end of the standard tank union.  My Model 88 has one modified in this way, and it's been there a long time.
If you feel that your bike just needs more oil flow, then get a Commando oil pump, and fit it with the 3-start pump worm as standard for your earlier bike.  The Commando pump has wider pressure and scavenge pinions, and so it will give more big end oil pressure and it will scavenge more efficiently.  Should you wish to purchase a new pump, this is your only choice - the earlier pump is not offered......
Hi Peter,
Here's the setup on my plunger Model 7. The oil line is not in it's actual position so you can see the set up. Rocker feed is on the return union in the oil tank.
