Anyone had troubles with the new thicker rev cables (before 3mm - now 3,15mm) .
It will not enter into the square section of rev. counter or speedo!
Are your speedo and tacho…
speedo
Hi Peter i bought a new speedo cable for my BSA it only did about 20 mile and stopped working the speedo head had been reconditioned and a new drive had been fitted the cable looked ok but when measured was slightly smaller square on the ends . i think it depends who is making them as you suggest .
Rev counter cable problems
I had exactly this problem with a new Rev counter cable I recently bought from Andover Norton.
I originally thought it was an issue with the Rev counter - some obstruction in place when trying to insert the cable ? I tested the Rev counter with an old cable and it was fine. I had to put the new cable in the vice and lightly filed the four sides whereupon it fitted.
Hope this helps.
Are your speedo and tacho reproductions or originals? this looks like a imperial cable square trying to enter a metric square hole.
You can get the opposite of this, a 3mm square cable engaging with a 1/8" speedo g/box drive,
It works for a while until the square bit gets worn and rounded, then no or very erratic speedo reading.
I think a lot of this comes about as to where the cable manufacturers get their components from
