I am in the process of resuscitating 1971 bike which, when I acquired it, hadn't run for about 3 years although was running when put away. As the PO is my brother in law I believe this to be true. I haven't touched the engine internals and I have sparks at the plugs which get appropriately wet when I crank the engine using my paddock starter. However the engine will not run apart from an occasional backfire.
Whilst working on the bike I replaced the wiring harness as the original one had been attacked by mice. I believe that I have replaced the harness correctly as all the lights and switches work correctly. However I am wondering if I have inadvertently reversed the LT feeds to the ignition coils. I.E. LT wire 1 is going to coil 2 and vice versa. Would this prevent the engine from starting?
If this is not the case then does anyone have any suggestions please?
What ignition do you have ?…
Thanks John, I have the…
Thanks John, I have the original point system so I will swop the leads and try again.
Thankfully I don't have to kick as I am using a paddock starter due to my advanced years and failing strength.
Al Os will probably come in but....
... I believe that it makes very little difference which way round they're connected. It will mean the spark is the opposite polarit but this should still work.
Ian, not sure that I agree…
Ian, not sure that I agree with you, surely if the lead from the points is going to the wrong coil then it will fire the wrong coil at the wrong time?
Maybe put this on the list to check...
Swap to new plugs? I now go with NGK. Have thrown out about 4 new/nearly new plugs due to misfires. Was on the point of pulling lots of the bike apart.
On my latest bike shipped as a non-runner from the states it seemed to take ages to figure out how much choke/tickling was required to start it and also seemed to change! Now seems to start best with full choke, and a little tickle but not so much as to come out of the carb. So maybe just trial and error.
I would also drain the float bowls and clean any crud out. Don't forget the guitar string down the idle port. Possibly clean the tank too. Check carb fuel filters. I had loads of rubbish that continually caused running and starting issues for months. I have now fitted extra glass filters under the taps as a 1st line of defence.
Eddie
Get it right.
Coil wiring. If using original points then each set of points MUST be connected to its specific Ignition coil for the engine to run. If using Boyer or Pazon etc then the coils are in series so which coil fires which cylinder is irrelevant. BUT the coils need to be wired in series + to - correctly, and with the overall +- in line with the battery +-. IF the coil's +- is reversed the spark is reduced but still works.
Thanks for the confirmation…
Thanks for the confirmation Alan
Thanks for all the help guys…
Thanks for all the help guys, the problem was reversed wiring to the coils. All sorted now.
It's amazing....
It's amazing how broad that grin is when the ol' girl fires up well after a non working issue.
Original points will require the correct LT to the correct coil, so swap them and start kicking again. With Electronic Ignition they are all wasted spark so it makes no difference.
