Hello,
I need to replace my timing cover on a 750 1971 but i'm not sure if its the same between a 750 or 850. I've notice that the later mk3 have a spring loaded piston against the pump outlet seal.
So wich one should i purchase? im looking for a used one.
If anyone got a spare for sale im in France.
Thanks for your answers
Pre MK3 850's work, its only…
Pre MK3 850's work, its only the MK3's you steer clear of unless you also do the related mod's, without these mod's you will have no oil pressure.
