Hi again everyone more problems with my bike in the title, for some reason the ignition warning light is staying on, since getting the bike a few months back and during this time until now the light was going out as it should with a slight increase in revs, that is with a new high output single phase stator, and new podtronics regulator and rectifier replacement system, last week it has started staying on regardless of revs, I am suspicious of the WLA (Warning light assimilator) which I have been told can be a problem the bike is fitted with the solid state one of these being a Mk3 so I have ordered a new one just in case but would welcome any advice to cure this my friend who is quite well up on auto electrics assures me the bike is giving out a charge but cannot find out why the light is staying on many thanks for your replies Chris
It's annoying when things…
Modern Regulators
I have had the same problem after fitting a Trispark Mosfet regulator to my Mk3, after replacing 3 warning light assimilators I emailed Trispark, Steve Kelly replied that the OE style assimilator is not compatible with modern type regulators, in my case the warning light would work correctly when the battery was accepting a charge but when the battery was fully charged the Reg would do its job and stop the charge therefor the red light would stay on, I confirmed this by switching my lights on which placed a drain on the battery.
Warning lights
Have a look at this link. https://www.improvingclassicmotorcycles.com/products.htm
Works great on my Mk3 fitted with a Trispark, 3 phase Alt, Mosfet reg.
Binned the capacitor . modified ignition harness.
Fit a voltmeter and it will…
Fit a voltmeter and it will tell what's really going on.
Found the battery status…
Found the battery status monitor that Julian suggested works well and much easier to see the colour of the LED with a quick glance than looking at a voltmeter.
Exactly
Check the charge voltage with a non 'cheap digital' . Cheap digital pick up ignition interference and readm rubbish. TGhen fit some form of voltmeter on the bike, a digital/LED device (I sell the BSM) will give you confirmation in a moment. The original Assimilator is known to upset reg/ rects as the Assim. switches the lamp to earth via output from the alternator. Reg/Rects don't like this. I can check Reg/Rects for the cost of the return postage.
Charging Light
Remove the bulb.
I have now removed the…
I have now removed the podtronics and replaced the 2 rectifiers and the light is still staying on yet the meter shows 14.5 volts at around 2000 revs someone please give me a solution apart from remove the bulb it did work so what has gone wrong new stator as well that was not needed
Either the unit is now…
Either the unit is now broken or more likely there is a connection issue from the alternator to the unit so it is not seeing the alternator voltage.
Bin it
Bin the WLA , even if it's new. I found the new ones do exactly what yours has done.
Replace it with a low voltage lamp driver from Al Osborn to power the red console light.
Also use a BSM, again from Al Osborn if you want to know what your charge system is doing.
Beauty about doing this is that you can site the units in the head lamp shell. Saying that, whilst your at the electrics why not rewire the bike. Get rid of all the crappy connector blocks under the tank and all the redundant wiring and make a neat job of it.
It's annoying when things don't work as they should, and I understand the urge to make them do so.
But apart from stubbornness is it really worth putting effort into this issue? All the warning light does is tell you that (a) the ignition is on, and (b) the engine is not turning. The second is obvious, and the first is easily checked.
Much more useful information is provided by one of Al Osborn's battery status monitors (usual disclaimer).
