Just getting started on my second MK3 restoration and wondered if anyone has any info on the availability of the left side switchgear housing and internals? When I did my last Mk3 a couple of years ago the Sparx items were available but now it seems they've discontinued them?
All I need is the internal switches and wiring as I can salvage the housing, but not having any luck on the net.
Steven, If you were not…
Thanks Andy,I was aware…
Thanks Andy,
I was aware there were other models with similar switch housing, but was worried the perch for the clutch lever might differ, although if the wiring and buttons are the same that would work as I can easily change the connectors.
Steven,
If you were not aware already. the Mk3 LH switch assembly is common to the Triumph T140E and later models, albeit with differing cable connectors. These switches appear quite frequently on eBay, though auction prices can sometimes become ridiculous.
Andy
