Hi all
Does anyone have a photo of how the inside Of the headlamp shell should be setup. Most curious part that im unsure of is the 3 holes down the bottom. Are they all sealed with rubber bungs for cables ? Photo would be great.
Photo of healdlamp shell in question attached.
Steve
Yes 3 grommets , 1 each for…
Front hole is speedo cable…
Front hole is speedo cable. Next is trip. Rear is wiring. All of course need rubber grommets.
The Lucas medallion is I believe available for the top centre hole. I believe it's supposed to be retained by a bezel.
Those lamp shells are almost irreplaceable. Don't lose it!
Reply David
Thanks for the info David.
The shell had an original medallion and bezel in it. I removed them for upcomming paint work. Hopfully can get the bezel and medallion back in easier than it was to get out.
Yeah i know they are getting tough to find.
In addition to above. 2
Thanks for the Photos Holger.
Some websites show a rubber grommet and say x3. But from all websites, it appears they are all the same size.
I need as you do, the x3 different sizes. Do you happen to know where to get the x3. I belive the holes are 21mm, 30mm and 40mm
Steve
Seems to me a bit unlikely…
Seems to me a bit unlikely that you will be able to find the correct grommets from old stock? , even if they exist they will be well perished ,I was able to look at a NOS boxed complete headlamp and they were on their way out. I expect you will be able to buy a box of assorted grommets and if one size is completely unavailiable cut 3 discs from an innertube and superglue them together to make your own !!
You do not...
need to get a new ammeter for 12V. Ammeters measure amps, they don't care about the volts. Also if the amps are reduced as the voltage is increased then the Ammeter will read a bit lower. On the other hand Ammeters are notoriously poor items so probably you need a new one anyway.
Yes 3 grommets , 1 each for the loom, speedo cable and trip winder. Looks like a shell for a coil ignition bike with the PSR8 switch. The tricky things to find are a reliable and complete switch with its plastic thread undamaged and correct bezel, A speedo cable with the 6" long heavilly armoured top outer and dimensionaly correct inner cable projection, An orriginal ampmeter with rubber gasket , a 120 mph chrono speedo with screw on bezel and intact trip mechanism, a Lucas medallion. and a headlamp with pilot and a decent light beam. All of these items can be bought as pattern spares but in the main the quality is well down on the orriginal bits.
