Motorcycle Hydraulic Lift
Hi All, I know there are various mentions of Lifts this on the forum but I would like to ensure I am getting the most recent information before I purchase a one. I have a 1976 MK3 Interstate and want a full table lift for cleaning and maintenance. Having read the discussions on this forum and masses of reviews I have decided to go with the Clark CML3 lift via Machine Mart:
https://www.machinemart.co.uk/p/cml3-hydraulic-motorcylce-lift/
There are cheaper versions on EBay but I am sure I will be able to get spares and a no quibble 12 month guarantee from Machine Mart.
Would anyone who has one for use with a Commando or similar recommend this lift? Are there any issues with loading a Commando on to the lift using the main stand? I am aware that using the stand will pull the bike back about 30cm (1ft) so it won’t engage properly with the front wheel chock. Is this a major problem? If it is I have considered a main stand dolly mover might work to push the bike back forwards???
One final question? I have a set of paddock stands for my bike. Would I be able to use these on the table to allow me to remove the rear wheel or are the lashing points of the lift sufficient to hold the front of the bike with tie down straps?
It’s a very expensive bit of kit so I don’t want to have any regrets after I purchase it. Thanks for any and all replies.
Kind Regards to All
Phil
I have one , it’s big!! So you need a couple of feet each side for a stool, it’s heavy to install , no issue ref center or side stands , I park there on the side stand and ratchet down if I want to jack up , pulls back a bit onto center stand but a tug forward slides the bike into the front clamp , the table top is a bit slippy if oily , when backing off down ramp don’t use front brake !! , and don’t stand on table , it can tip even as heavy as it is , some wood blocks under a good idea .
I did some initial restoration work crawling around on my hands and knees and eventually plunged for a bike lift. Best thing I ever did. I looked for ages on eBay for used lifts but soon realised many had a hard life and most were nearly the price of a new one when shipping was included. I bought a new lift from https://www.sgs-engineering.com/. Really happy with it and expect to recover most of the expense if I chose to sell it. I will try dig out the model but it has a ramp and wheel chock with a pneumatic ram. The bike fits on even when the ramp is removed for easier access to the bike.
https://images.app.goo.gl/cLeNYxSWqgTtvfX9A
Thank you ever so much Guy’s for your replies which are very much appreciated. I am now having second thoughts that perhaps the Clark Stand maybe too big as Robert mentioned. I do have almost 2 feet either side to work with but my second choice stand is a good 6” narrower and 4 inches shorter so that’s edging it now as well as £75 or so cheaper. I really like the SGS stand Martin it looks awesome in the pictures. However, I do not have an air compressor and they are out of stock if I’m looking at the correct model on the site. If you do have the exact model number please do let me know. If I was really short on space I would of snapped up Sealey stand Martin and have to say I really appreciate your detailed description of pro’s and con’s.
Kind Regards
Phil
I purchased a Machine Mart CML3 about three years ago. Best bit of kit I have purchased. I have managed to do lots of repairs sat on a stool! I also purchased the stool at the same time. The lift comes with a locking bar. Use this bar, as over time the the lift will loose pressure and slowly lower itself, It did take a couple of months to do this from a 2ft lift. The wheel chock came with mine. I paid about £450 for mine, they have gone up a lot in price since then
John.
... I went for the cheaper ATV / motorcycle lift like this:
https://www.ebay.co.uk/itm/185485080002
It can be a bit of a faff getting the bike on but like the one mentioned by Martin it leaves front and rear wheels free. It can be a bit tippy but used carefully it's fine. It also folds down low enough to go under the bench.
I like the idea of a platform type but to my mind they take up far too much floor space, even though now my garage is much bigger than the one I had in the pic.
Sunbeam on lift
I have used a similar one to the Clarke for a couple of years. Seems there is a number of different priced ones which looks the same. You have to add a few hook points. Never liked the front clamp. I've seen that if you fit a front wheel stand similar to https://www.louis.eu/artikel/steadystand-fix-152-front-wheel-clamp/10002863 you can get the bike on the stand single handed. A scissor lift like https://www.machinemart.co.uk/p/draper-mcpl2-motorcycle-frame-scissor-lift/ is very useful on the lift. I also often use paddock stands on the lift. Except for  a 16H which has a rear stand. I have 3 feet free space on each side.
Hello Phillip, regarding a lift,  you might also check the mode of operation. My friends and my lift both have the same max working height with two alternatives, these are chosen by inserting a bar in predetermined positions,  the pressure then being released takes the load off the ram.        My friend's lift works on the principle of a parrallellagram,  therefore when lowered from working height the platform effectively moves forward about eighteen inches so this needs to be allowed for. My lift, like my friends is full size although four inches narrower and works on a scissors principle.  This means that the platform rises and falls within the space that the base occupies. It's worth thinking about if space is at a premium.
