Have the original fibreglass tank on my 69. I lined it with POR15 tank sealer and thought I was home free. Lining now bubbling and lifting which is very disappointing as I have always been a big fan of POR15 products and thought I had prepped the tank well.
Anyway. I have ordered a new steel tank.
Problem: The carb slides were sticking badly (virtually seized) and have now discovered the carbs are covered internally with a sticky gum that extends inside the the head inlet ports.
Carbs and ports now cleaned. Kicked myself for thinking I could get away without swapping the tank on day one. Didn't realise that the lining was mixing with the petrol and causing major issues- I had paper filters on both taps which this stuff went straight through.
Question: Should I pull the head to check and clean the valve seats and faces and chamber/piston or should this goo clear itself.
Thx
Eddie
Valve stem and guides…
Tank Sealing (Dross Alert)
Before ethanol was added to petrol; I don't recall such issues.
The Petseal in my slimline tank had dissolved over time (This was 2006/07) I only found out when the tickler became stuck, then I saw the mess in the tank.
What worked for me: I emptied the tank and removed soft sealant as best I could. Fortunately there were no holes in the tank. I also bought a new Amal 626 26 mm carb.
With the tank inside dry , what was left of the Petseal became hard and broke up easily, a good shake required.to get it out and fuel filter fitted.
I then put E0 petrol in the tank and all has been well since. The engine continued to run very well and been left since. (As John suggests: by all means take the head off for piece of mind)
Why we need to use scarce wheat to make this awful stuff I can only put down to politics.
BTW, it appears that additives only slow down the destructive process. Not the cure. But if you insist on using E fuel then run the carb / carbs dry if parking up for a while.
Hi Eddie. I had the same…
Hi Eddie. I had the same problem with a Triumph tank (steel). As well as the carb slide and jets being jammed up with sealant goo, the valve guides had a layer of sticky gum in them which caused the valves to operate poorly. I stripped the head down completely and washed everything in cellulose thinners - problem solved. Good luck with sorting it.
POR 15
Hi Mike. I reckon you are right. I assumed it was ok with fibre glass as the standard POR15 works fine with it. I coated a fibre glass shower tray with grey POR15 about 15 years ago and its perfect.
Just looked up the instructions. Oh well. The tank was on borrowed time anyway.
Eddie
Valve stem and guides especially inlet need cleaning so it's a head off job anyway. Acetone should remove the residue.
