What is the purpose of two grooves cut into kickstart shaft,thought o ring oil seal has cork seal other end?
Which gearbox ? Are you…
Gearbox laydown
Kickstart shaft itself.
On the later boxes only the…
On the later boxes only the layshaft at the kicker end is scrolled and the kickstart shaft is plain, looking at Andover Norton's drawing of the Laydown box it is the same. The kickstart shaft only rotates in the cover bush when you kick but the layshaft turns all the time so that makes sense. Sounds like a DPO mod that will create a leak.
Hopefully someone who has been inside a laydown box can confirm.
Gearbox laydown
Hi John
Thanks for the reply, have two other kickstart shafts with the two grooves the same.
Also which way round does little gear next to kickstart pinion on mainshaft go round has a small shoulder one side of gear bigger the other next to packing washer, laydown gearbox.
That needs to be answered by…
That needs to be answered by someone with knowledge of the Laydown, maybe if you post in the singles section or the heavy twins more people will answer.
This thread is in singles
https://www.nortonownersclub.org/node/13425
and is asking about the Laydown gearbox.
On the first gear I would look at the inner cover, if the mainshaft support bearing is recessed like it is on the AMC gearbox then the shoulder is outwards so both first gears mesh fully and to stop the mainshaft first from chewing away at the cover.
Which gearbox ?
Are you talking the kickstart end of the layshaft or the kickstart shaft itself ?
