Hi All
I'm sure we have been here before. But I could not find the info I needed on the forum. What I would like to know is the carb settings for this particular carb, when fitted to a 1961 ES2. Thanks in anticipation.
I have a 61 big bore ES2 …
I have a 61 big bore ES2 (530cc) with a 928 carb. Sorry I can't remember the needle position or slide (Either 3 or 31/2) But the main jet is 240. (Smaller than the mono block 270)
I also have a poor man's Manx (59) on standard bore with a 3 1/2 slide and a 230 main jet. Again, sorry I can't remember the needle position. But this is a 930 carb.
The main jet on a concentric should be smaller than on a mono block, some say 20% but it is really what works best, as no two bikes are the same.
Hope this helps.
Hi Don and Neil. I'll try…
Hi Don and Neil. I'll try the 3 slide and 180 main jet and see how it runs.
Hello again Bike running…
Hello again
Bike running well now. Thanks both. Used a 4 slide ( which I already had), needle in top groove. All good now, like a sewing machine.
Pete Shoemark Manual
Neil, you may be onto something.
I have not tried to get top speed from my ES2 yet, and I would be surprised if it does make the full 80mph.
The manual I use in tuning any carbies is ' Motorcycle Carburettor Manual' by Pete Shoemark. His last line in plug chops was along the lines of " when you find the ideal main jet size, keep increasing the jet size until power drops off AS THERE IS MORE POWER TO BE GAINED!
I followed this reasoning in my Mikuni equipped Atlas. But not on the ES2 for some reason. Maybe 200 or 210 would liberate a few more mph.
Also bear in mind all my bikes run aircleaner s.
Main Jet.
Hi Don,
I would still be interested to see what a 180 would pull on an ES2 with standard gearing. Engine 20T and G box 19T.
I reckon about 65.(Without wind or slope assistance)
I think 210 would be in the right direction (Model 50 with no air filter) But 240 open end and 230 with a filter on an ES2. (As in your case) A lot more dust down under.......
Good luck and happy trails.....
Easily Pull 65 MPH
Neil,
I'm assuming my bike has standard gearing, it will easily pull 65 mph. It has a metric Speedo and I've had it to 110kmh which is the maximum legal speed here. 110kmh is 68 mph. I feel it has a good 5 mph left in it, but time will tell.
I use a 200 main jet, 106…
I use a 200 main jet, 106 needle jet, needle in the top groove and a 3.25 slide on my ‘52 ES2 with a 928 concentric. Good for about 68 mpg on a recent trip, but no idea of the top speed - it cruises happily at 60 mph.
john
I always...
... start with a main jet that I know is too big then reduce the size. My thinking is that I rarely use wide open throttle so carburation further down the range is much more important to me - especially coming off idle (cutaway) and roll-on mid throttle (needle).
Actually, I often just leave the too-big main jet in as it doesn't do any harm for my riding "style"......
Hi All Have just returned…
Hi All
Have just returned from a ride on the ES2. Concentric 928 carb set up as described above- 4 slide, needle in top groove and 180 main jet. Gerbox sprocket is one tooth up. Managed an indicated 70mph before slowing down to a cruising speed of 55-60, which the bike can maintain all day. My 'carb problem' was down to a faulty condenser!! I'll try a 200 main jet soon and report back. Thanks again to all contributors.
Time will tell
Hi Don,
Yes I forgot the more restrictive speed limits down under. 100 kph in NZ, that's just 62 mph. And camera's all over, especially in shaky City. In the UK it is 70 mph max (A shade under 113 kph)
I feel those max speeds are enough to make a difference though. As Harry said, his bike runs out of puff @ 70 mph. I would expect that from one of my Model 50's, but a little more than 10 mph extra for an ES2. Then there is the easy feeling aspect of knowing there is another 20 mph in the pot at 60 mph. If the performance is there you have a choice but without it you are constrained.
A matter of choice but it seems the answer is in the main jet where size matters....If I can say that without offending anyone?
Harry,
I have a 928 on my 1956 ES2, so apart from the ignition it should be similar. BTW it has a Triumph style pancake paper filter and I have removed the choke slide completely . I used plug chops to get the main jet size.
Main jet 180
Needle 106
Slide 3
Airscrew 1.25 turns.
It runs very well and idles extremely well.
Only issue is it is a Left Hand unit off an A65 I think, which is a bit of a phaff.
Don Anson Australia
