I'm sorting out some bits on my new to me MK3 1978 Commando including front brake rebore, fitting new starter motor etc.. As I am a novice/ learning about maintenance on classic motorcycles, once done (and as it involves the brakes etc.) I was thinking of getting it checked out and potentially serviced again so it is safe, for peace of mind - could anyone recommend someone who could do this in the Manchester area? I had a look on the service part of this site but assume there aren't many that offer this as most people do it themselves. Anyway any help would be great. Thanks,
Nathan
MK3 upgrades
And pay for the optional MOT…
And pay for the optional MOT test...
great thanks Brian and David
I suggest that you contact…
I suggest that you contact Peter Shand. He rebored my master cylinder and is well known for his starter motor upgrades. He is not that far from you either.
Thanks Steve will do. Nathan
Items to consider:
# Upgrade starter motors cable before adding brushes to the motor.
Andover Norton 06.7269
# Inspect gear box lay shaft bearing - see previous notes.
# Review front brake master cylinder options:
% Sleeve existing to 13mm (RGM)
% Buy replacement 13mm unit (Andover Norton) 06.5742/13
% Buy replacement 13mm unit (Andover Norton) from Triumph T140E 60.7163
# Buy Avon Roadrider MK2 tyres
