I am still trying to find the thread forms used on my 650SS. At the moment I am specifically looking for the thread used on part number 04-3441 clutch stud, is it whitworth or BSF or ...?
Philip H pointed me towards the heavy twins compendium, it was interesting and useful except this stud was not mentioned.
I have a mertic/whitworth thread gauge but cannot find a BSF gauge. Any suggestions?
I am thinking of buying a range of various Imperial nuts and bolts in order to find out threads by selection.
Is there a thread gauge chart I can buy.
Thanks in advance. Roger
Most likely to be 26 tpi…
Your Whitworth thread gauge…
Your Whitworth thread gauge is also BSF, they are the same thread form just the diameters differ. Buy a Zeus book, a little pocket book, it will list most standard threads, BSW, BSF, BSP, UNF & C and pipe threads. BSC are nearly all 26 TPI and have their own thread form. Best of luck.
Dick.
Online
Roger.......I got most of my Nuts, Bots, Studs & Threads information online. There are stacks of sites that offer this information free for most common Imperial and Metric threads. Also there are a few sites which offer thread comparison data which is quite handy for finding modern WW equivalents among UNF/UNC offerings.
Parts database, you don't…
Parts database, you don't have to sign up but if you do then you can edit the database.
https://www.gregmarsh.com/MC/PartsList.aspx
Most likely to be 26 tpi cycle , this fine thread used a lot on steel bolts and studs to resist vibration . Often linked up with whitworth when going into alloy castings..
