I have recently overhauled my early AMC box. All new bearings and bushes including a new main shaft. On rebuild I can get all four gears no issues, all good.
First start of the bike seemed OK but then later start noted the KS not returning on the spring and moving the KS turns the rear wheel either way. Something a miss so box stripped again.
When kicking the bike over it appears the rear wheel appears to turn, as if its binding somehow. If I hold the rear wheel the kickstart becomes really stiff. I have had the box stripped a few times and can't see any issues.
I have noted though that if I remove the outer cover and KS spring and press down on the KS shaft, I get the same binding issue, as if the KS shaft is binding on the layshaft and turning the pinion at the sleeve gear end and thus rotating the sprocket.
Any ideas what may be wrong? I'm out of ideas.
With the kick-start fully…
Yes, rear turns free when KS…
Yes, rear turns free when KS is in normal position and box in neutral.
Tight clearance somewhere?
The layshaft runs in a bush inside the kickstart shaft if I remember correctly. Did you change that bush? If that bush was tight on shaft and bushes supporting the kickstart shaft were a bit loose, maybe kickstart shaft is twisting and grabbing the layshaft and turning it.
KS shaft bush was changed…
KS shaft bush was changed and measurements taken on layshaft and new bush. All within tolerance.
Good point on the steel KS bushes. They were not changed and there is a fair bit of rock in those.
I fitted a new Layshaft…
I fitted a new Layshaft roller bearing, carefully measured the end float with a Dial gauge and fitted Isso shims allowing 10 thou float. That just locked it all up !!. I then took Hemmings advice and forgot the shims , let it all hang out ! . Worked fine.
Still having Issues - Kickstart
Well, two new inner and outer case kickstart bushes and a new kickstart shaft later, I still have issues with the kickstart shaft appearing to bind on the layshaft and turn the rear wheel when full kicking pressure is applied to the kickstart. Surely this is not right and the rear wheel shouldn't be getting dragged around when kicking over?
Does anyone have any idea what my issue may be? As mentioned above, all bearings and bushes are renewed.
Thanks in advance.
Sounds like a bush is too…
Sounds like a bush is too tight, there are pattern parts around that are not good. Also the 4th gear can be fitted the wrong way round.
They all seem OK Robert. All…
They all seem OK Robert. All parts from reputable supplier. Kickstart shaft and bush fit layshaft nicely and with belt drive removed the kick start mechanism all operates smooth as silk. Only when full kick load is applied, with KS parallel to the ground, do things seem to bind.
The new new KS shaft and bushes have definitely made a positive difference but still doesn't seem quite right.
With all assembled can you…
With all assembled can you feel a trace of end float on the KS in all its arc ?. Too much radial play in the KS bush gave me some similar issues. The old issue with a bad clutch spider axially loading up the box and clamping the mainshaft to the sleeve gear gives some odd issues and is very hard to spot.
All assembled there is end…
All assembled there is end float around all of the KS arc. Radial play is very small as KS and bushes are all brand new.
You have got me wondering about the clutch side of things though. It has a diaphragm type clutch fitted. I'll give that some looking at.
Gearbox Gremlins
Several areas that I would be checking.......some mentioned above already.
1) For the kick start to be in neutral and yet still turn the rear wheel there has to be unwanted stiction somewhere in the gear circuit. The Layshaft 4th (Kickstart) should spin freely on the Layshaft. If it is binding this will turn the 4th Layshaft which in turn will spin the gearbox sprocket.
2) Still in neutral, operating the kick start turns Layshaft 4th and Mainshaft 4th. If the bushes inside the Layshaft 1st (output) gear are binding with the Mainshaft then both will turn and try and rotate the rear wheel.
3) The kickstart shaft bush/bearing is binding on the Layshaft. Check the shaft hole is concentric.
4) Most unlikely but possible.....one of the drive chains is far too tight and causing stiction between the gearbox Mainshaft and Output shafts. A bit like (2) above.
Thanks for those points, I…
Thanks for those points, I'll get those areas looked at. Its very odd. When together the box operates fine in every other respect.
All rechecked but I’m damed…
All rechecked but I’m damed if I can find the issue. Looking like a gearbox out job and closer inspection form an expert.
Thanks for the tip.
I’ll check that out. It’s going to be something like that I guess. I ah e take. All other gears out other than those involved in KS chain and still have the issue.
Slacken the gearbox mounting…
Slacken the gearbox mounting bolts and recheck, it most probably distorted a little in use.
Quick update folks. Did…
Quick update folks. Did slackening G/B bolts with no effect.
I have also replaced the layshaft today but STILL have the same issues. When I ran the bike for 5 mins on the stand, in gear. Whilst things ran OK, when I stopped the motor the kickstart was totally bound up with all end float on the K/S shaft gone.
I am now totally out of bullets. I was sure the L/S would sort things but if anything, things are worse.
Sometimes a fresh pair of…
Sometimes a fresh pair of eyes will spot something, where abouts are you? , there may be someone near.
The early AMC box uses a…
The early AMC box uses a different shaft and spring and inner cover to the later box ,could you have a mixture somewhere?.
It is an earlier N series box.
I’ll double check the types. I’m in Northwich, Cheshire. Thanks.
I now have
the box out of the bike and stripped again and can replicate the issue on the bench. Just to recap... Kickstart action drags rear wheel around, blocking the kickstart action. I can block the sprocket when applying pressure to the kickstart when testing on the bench. The box has had:
- All new bushes and bearings. Including inner and outer cover kickstart bushes.
- New Main shaft, new layshaft.
- New Kickstart shaft and bushes,
- New Sleeve gear and bushes.
I can select all four gears when built up no issue at all. Not sure theres anything else to change the than shell, inner, outer cover! :)
Any ideas anyone?
Is the kick-start pawl too…
Is the kick-start pawl too wide? Or the wrong way round? Jamming somehow?
Primary chain tension…
Primary chain tension possibly
Good shout, I'll check the…
Good shout, I'll check the pawl side.
Ashley, I am getting the same issue when box is out of the bike. If I apply pressure to the kickstart by hand with the clutch holding tool I'm place it locks up the drive sprocket, similar to the clutch being on the bike.
I was hoping my new AN sleeve gear would sort the issue :) as I was thinking there was quite a bit of play on the gear/bearing interface and that was somehow binding on the mainshaft but seems that isn't the issue.
Its very odd. When all setup on the bike, when you kick it over it drags that much it blocks the full action of the kickstart. When on a paddock stand it turns the rear wheel. If you apply pressure to the kickstart at around 9 o'clock and then try turning the wheel its pretty much locked up.
The other thing is to check…
The other thing is to check the clutch is not done up with the inside abutting the sleeve gear. If the clutch or shims used to fit the clutch touch the end of the sleeve gear this will lock the sleeve gear and the mainshaft together. If you are using the original clutch centre is the brazed in washer still in the bottom of the spline, if this is missing then the clutch will be able to sit too far inboard.
I’ve used Dave Coates for…
I’ve used Dave Coates for gearbox and clutch working the past, he might be worth a ring. I think he charges £50-60 to rebuild a box plus any parts. He has a lot of experience/knowledge. He rebuilds boxes and clutches for the pre unit Scrambles bikes but is in the SE I think. He certainly used to go to Shelton and Kempton.
dan
At Kempton
there is a regular jumbler who has a stall with Norton stuff near the entrance, in front of the grandstand. Is that Dave Coates? If so, how do I contact him?
I ask because a jumbler with a stall there said he has fitted AMC cam-plates to Norton boxes. I may get that done to the horizontal box in my '55 Model 88.
Kick Start Stiff
The kick start operates on the Layshaft. This turns the 4th Layshaft Gear which then rotates the Output Sleeve Gear to which the sprocket is bolted. In Neutral...... for the Layshaft to turn the Mainshaft / Clutch either the clutch is binding on / against the Output Sleeve Gear or somewhere in the gear train a set of gears turned by the Layshaft is trying to turn the Mainshaft. Possibly due to the Mainshaft 2nd or Layshaft 3rd gear pairing dogs engaging when they shouldn't or a bush in either of these gears being too tight.
One other possibility being that ........what you think is neutral is actually a selected gear???
Clutch is not fouling
The sleeve gear. Checked that. Also had box apart again and checked the k/s pawl. All seems fine.
I can get the problem if I take off the clutch and also empty the box of all gears, other than the sleeve gear, layshaft 4th, layshaft first and main shaft first.
If I set up that way in the bench and apply pressure to the kickstart it locks up he sleeve gear, which when in the bike translates to dragging the rear.
Can someone please confirm that when they kick their dominator on to compression and hold it there as if ready to kick start that the rear wheel still turns freely, if off the floor, and is not dragged around.
I’d really appreciate that as currently I am thinking I have a problem that doesn’t actually exist.
There is usually some small…
There is usually some small amount of clutch drag on Norton Singles. When they are started on the rear stand with the rear wheel off the ground, the rear wheel almost always turns..or even spins...and a touch on the brake pedal confirms it really is in neutral before pushing it off the stand. The Dommie would no doubt be exactly the same if it had a rear stand.
Dommie kickstart issues
Not sure if this applies to your problem:
I note you have a diaphragm clutch fitted [belt drive]. When I fitted a belt drive to my 650ss I had a similar problem. When tightening up the Clutch centre nut the gearbox/back wheel locked up. I had to have 1mm machined off the back of the diaphragm clutch body to free everything up. Is this a new Belt Drive kit?
It is a diaphragm clutch but…
It is a diaphragm clutch but was in the bike before strip down and was all working OK. What I have done is overhaul the gearbox with all new bearings bushes and shafts. I have the box on the bench and can see at least 2-3mm gap between end of sleeve gear and clutch body.
I can hold the clutch body and operate the kickstart with pressure and lock out the gearbox sprocket/sleeve gear. It something I would expect as it affect the kickstarting of the bike.
Anyone want to
for me that their dominator/single does not stop the wheel when the kickstart is under pressure i.e under the foot! Can you still turn the rear wheel?
Kickstart binding
Rather late to the party - but I had a similar issue on a laydown box and had it apart many times. The problem turned out to be a new layshaft bush in the kickstart shaft that had been bored crooked. What lit the lightbulb was that if I substituted the K/S shaft with one where the bush was worn out, it was fine. Ended up replacing the bush and having it very accurately bored and reamed in a lathe with a 4 jaw chuck. Worked fine after that.
Dominator Kick-start Issues
Hi Alistair
Did you sort the problem? Missed this discussion, just found it.
I had exact problem with my 650ss, 4yrs ago after fitting
Kick-start shaft and new spring. Then another new Kick-start shaft.
Same problem. Both from Norton Dealers.
My bike has original chain primary.
Answer? Correctly checking end-float on Kick-start shaft
Then shelling out £30 + on an expanding reamer to remove
the tiniest sliver of material from outer over Kick-start bush.
Tim
With the kick-start fully returned and the GB in neutral, does the rear wheel turn freely?
