My 1962 650SS has twin concentrics. The one on the right hand side [gear lever side] is 930/R92 while the LHS although is also a 930 but there is no 'R' number but just a stamped number 10.
The carburettors are still on the bike so seeing the LHS carburettor is a little difficult but certainly there is no 'R' number.
My Green Maintenance Manual shows the carburettors should be Monobloc 376.
Are the Concentrics a sensible conversion? If yes what main jet size, cutaway and needle position etc. should I have?
Regarding the groove setting on the taper needle does the numbering always start from the top? My needles have 3 grooves so I presume position number 1 is in the top groove?
Many thanks for clarifications. Roger
R stands for Right, L for…
Our Atlas came as standard…
Our Atlas came as standard with twin concentrics and I could not get rid fast enough !!. A cheap fast wearing bit of junk . A conversion to a single monoblock was done ASAP and not regreted. Sorry if thats a bit of a downer.
Single Carb
My 64 engined 650SS runs with a single R/H 930 and goes very well.
Sounds like all that is needed is a 2-1 manifold and set up as per Mercury.
This includes a 280 main jet. You can also expect 70 mpg.
PS: The new Amal's appear to be made so much better.
Is this what 'build back better' means?
Thank you guys and yes…
Thank you guys and yes constant development. Roger
If the bodies are good and…
If the bodies are good and it's going well, I would still change to chromed or hard anodised slides to reduce future wear. I just swapped concentrics on my 88SS for monoblocs. It's a fiddly job. Cable outers are a different length. Number 1 is the top groove.
Decision Time
Thanks again for your comments. Now I have a decision to take. In the first instance I would like to try with twin carbs even if I opt for one single later on.
Both carburettors are 930s so can I assume they are essentially the same?
If not what is the difference?
If there are differences can I carry on and use both with both having the specified jets/needles/cutaways etc?
If I decide on a single carb. which is best, Monobloc, Concentric or one of the later carburettos?
Many thanks again Roger
Monoblocs are more expensive…
Monoblocs are more expensive but correct. If you have the bits to fit one type it's easier to stick with it because the cables are different. Also it's cheaper to set up one and get that right first because the settings for two should be the same. My two concentrics on the 88SS show no obvious wear after about 10k miles with chrome slides. I've now fitted monoblocs for the sake mostly of appearance, but Phil ( of this parish) warns me that there is some evidence that the chopped float monobloc might lead to some fueling issues..more to worry about. The opposite hand monobloc is no longer made by Burlen.
Chopped float monoblock issues.
I have a pair of monobollocks with the chopped float on my 650, and there are times when making 'good progress' that I get some fuel starvation. What I don't know is whether it is the fuel tap, float valve or float chamber exit where the restriction lies. As it only occurs at sustained speeds above 5000rpm and full throttle, and the fueling is so good everywhere else, it isn't something I feel needs fixing in any hurry.
Biggest issue (if you can call it that) is that the mixture screws are hard to access on the left carb with a pair fitted.
Regards, George
I wonder if this is why the…
I wonder if this is why the bottom intercontonnecting banjos take a bigger diameter hose than the main feed? Is that a relatively modern update in an effort to solve the matter? I bought some nice new supply hose with mine, but couldn't finish the fitting.
Chopped for reason...
Ian; the RH is chopped as it wouldn't fit alongside the LH one which is whole, and extending that would not cure the issue.
David; try fitting a knurled TT pilot adjust to the screw. All I did was bore the original screw enough to locate the cut down jet and put a cross pin in the shank to fit into the screwdriver slot. Once setup you can remove it.
George: I thought I had similar issues when on the gas, suspected fuel flow (as per David above) wasn't sure so removed tap which was a bit cruddy. Fitted a clear fuel filter in line to see if I was creating debris in the tank and hey presto it was clean art all openings.
Either the tap cleaning or the fact that I had introduced a large plenum in the line by way of the fuel filter giving a slight increase in available fuel eradicated the problem.
Then there is always that miniscule breather hole in the filler cap????
R stands for Right, L for Left but looks to be missing from yours. Your left one stamped 10 is off a Triumph T120R 1969.
