Lately I have been struggling with an unreliable gear change on the 99. It has standard and orriginal parts ,but my size 9/10 boots (Daytona's ) just won't fit under easily for up changes. Tried repositioning lever and rest but the only workable situation puts the rests low enough to discourage the usual joyfull excess needed to put my boys in their place !. Is there a longer lever from another AMC box that might work?.
It might...
Thanks guys, I am trying to…
Thanks guys, I am trying to keep the std look if possible I expect I will have to do the opposite to what I did with the Rudge which had a riddiculous long nearside gear lever. A local engineer cut out an inch and invisibly welded it back together , I expect I have the offcut , so the Norton will be part Rudge !!.
... be worth getting a used lever and lengthening it with a plate along the side. I did something like that with a Honda which gave me a similar problem (although worse as I'm a size 12!).
