Would someone know the thread sizes of the 2 bolts that go into the back of the oil tank and the two screws that fasten the tachometer drive to the timing cover? Both are fine thread.
Bolts in the tank are most…
As Robert implies...don't…
As Robert implies...don't make the mistake of expecting BSF.
Atlas threads
Hi Jim, the timing cover/tachometer screws are 2ba,4mm washers will fit. Neil.
Bolts in the tank are most likely 1/4 cycle
