+30" Jubilee pistons
I'm going to ask a million dollar question! Please, does anyone have a pair of +30" Jubilee pistons that I could buy. Preferably I would like them to be in better condition than the ones I have taken out of my bikes engine. My Jubilee has spent the past year standing on my ramp in the vague hope that a pair of pistons might turn up. I've looked under many stones and even rummaged in Pandora's box, all to no avail. I'm rapidly losing hope. If anyone knows of some strange place on another planet where I might possibly trip over a 'flowering' Jubilee piston tree, please let me know. In the meantime I might be forced to ask/plead with the NOC to please have some made.
Even though I have some new rings, I really don't want to fit the old pistons back in. They have done their time and have quite obviously nipped up in the past. Once on the North Circular, many years ago, going to a NOC Rally. Brooklands I believe it was.
Annoyingly, there is a man in Stavely who claims to have a pair of plus 30s, but I can't prize them out of his collection; even for his astronomical asking price. Lets face it, if you sell the last of something, you then can't claim to have any, and that's no way to run a business!
Is anyone else in the 250cc piston market?
Have you considered getting your old pistons ceramic or similar coated on the skirt to restore them. As long as your ring slots and gudgeon pin holes as good then it should be possible to clean up the OD and get the coating to bring it back to size.
Norton supplier on big twins
https://jsmotorsport.com/product/piston-skirt-coating/
.. to match them with alternatives eg from JP pistons? They don't list the Jubilee but they have a catalogue that you may be able to search for something suitable.
https://www.norndaautomotive.com.au/jp-pistons.html
Or how about a Honda C77/CS77 on this list? Correct bore.....
https://4-stroke.net/library/honda-piston-size-chart
If you could go to 61 mm (.040 overbore) there are loads on the list to sort through.....
JP pistons process is to make a larger range of pistons from as few blanks as possible, most end up a lot heavier than the originals. Add in their useless rings which may never bed in and their habit of leaving off a machining operation, they are best used as an absolute last resort.
... may well be true but (a) I was suggesting finding another piston that may fit - not necessarily from JP - and (b) better a bad pair of pistons than a useless ornament in the garage.
I was only referencing JP from bitter experience of finding all the noted faults twice thankfully not on my rebuilds but where I was asked to sort the issues out. I made no mention of your other suggestions so not sure why you thought I dissed any suggestion other than JP.
Hey guys, simmer down. I didn't want to start 'Norton Wars'. Thanks for the ideas though. I'm afraid that I'm just plain daft enough to want an easy life and to be able to fit a pair of pistons that haven't been specially boiled in liquid liquorice, or thrown from the top of the Shard to get a super fast glaze. It must be possible, using CAD to get pistons produced 'relatively' cheaper than in the past. But then, what do I know? I'm just trying to keep a Norton on the road.
Hi Kev,
It's surprising how difficult it is to get some parts for Norton Lightweights. Not long ago everyone re-bored their bike almost as routine whenever the barrels were off. Good for Hepworth and Grandage in Bradford and all the Norton dealers. I can confirm that Hepworth and Grandage are now levelled (Morrisons I think) and the Hepolite piston supply  is well and truly turned off. When the pipeline runs out.......... just as you found out.
Truly, how much are you going to ride this bike? If it slaps a bit when cold are you going to notice above the rest of the noises? If it burns a bit of oil, do you really mind?
Did you get the piston on e-bay spotted by Dan?
I've searched all over on your behalf and can't find another.
I hope it's obvious which way to go. Like it or not.
Sorry, Kev - public apology....
We did talk about this at Norton Day - but sadly I have been a bit involved in a house selling/buying nightmare. Don't let anyone tell you that this the most stressful thing you will do in your life. They are all wrong - its more than twice as stressful as that! Esp when your Solicitor goes missing on Completion day..........
I do not think I have +30 Jubilee pistons after all.
If you have existing pistons, you could/should try cleaning them up. Better a bit of piston slap when cold, then seizing when hot. Back in the day, engineering companies discovered that Jubilees re-bored as per the book could very easily seize up, due to the deeply spigotted barrels and poor heat dissipation. So an experienced engineering shop would add a thou or two to the dimensions, giving that bit of extra piston to cylinder clearance.
... the light use that most older bikes are subject to I always have rebores a couple of thou bigger than the book value. It saves all (or most of) that tedious running in, and piston slap with that much clearance won't be too bad. Edgar Franks suggested a rebore on my ES2 when the wear was more than .007".....
I bought/won the +30" piston advertised on Ebay. Dirt cheap, (cheers Dan), and luckily after a quick check it seems to be in cracking condition. Far better than either of mine. The question now is; do I wait for another one to turn up, or what?
I find it disappointing to discover that we have reached the stage where instead of creating engineering delight, people are happy to allow their Nortons to slap about the countryside rather than use their service (the Club) to alleviate what seems to be a genuine problem. I can't help wondering what would happen if Commando 750 pistons at +30" suddenly became unavailable and industry said they were unlikely to produce any more.
If my bike is running the way I want it to run, I am more likely to ride it. If it slaps about the countryside leaving a trail of smoke in its wake it will probably stay in the shed. Shame!
Thanks for your efforts also Peter. I hope you will keep an eye open for me. None of the above is intended as a dig.
Happy slapping.
My ES2 with a bore about .002" bigger than standard doesn't actually make an appreciable noise and burns no oil whatsoever. It does however run like a top and accelerates in a very satisfying way. But you are of course entitled to do whatever you wish. I'd rather have a running bike than an ornament in the garage however "correct".
https://www.youtube.com/watch?v=y6IMRXgZE8k
https://www.youtube.com/watch?v=31FqpkF2PK0
For no reason other than it seemed to be mechanically busy, when out riding it I always considered my Jubilee engine to be a hand grenade waiting to go off. Though I did occasionally hit 70 I rarely rode it faster than 60mph, because at higher speeds I had a vision of oily parts scattered all down the road. To add to the mix an engine that I'd done half a job on, (in my opinion), would fill me full of those awful thoughts of impending doom and I'd feel obliged to crawl along at 50mph just in case. After a rebuild, 'engine suicide' seems to be a dreadful waste of time.
I've spoken to people who used to sell the things new to learner riders. It wasn't something they liked to talk about.
I did ride mine on occasion with the big boys on the motorway, but I'll admit I slowed them down somewhat.
Being the only Brit four stroke twin, the Jubilee is a strange little beast and deserves our best efforts to keep it running in finest fettle. The necessary engine parts for those who choose to buy them would be a great bonus. For those of you who remember him, I'm sure that Orsom Weels would agree.
Nice looking bike, Kev.
Unusual to see Roadholder forks on a Jubilee.
The great advantage of a Jubilee is that the barrels can be removed individually.
You can run with one new piston and one older piston.
Then, when the next new + 030 piston turns up, pop it in.
Better make a written note of which side you put the new piston. It may be a while.
Hope to see you on this bike next year. Cut your own trail at your own speed. If the rest find it a bit slow - they need to learn respect.
She was Roadholder No 221 cover girl, (shame about the bloke sitting on her), back when my Commando was just an alternative ride and the Jubilee was a pleasure to go out on. She also won 'The lightweight you would most like to go home on' prize at Brooklands, and she wasn't even the only one there.
The Roadholders were on her when I bought her in 1984 and renewing the steering bearings was quite a challenge. Nav - Jub. She's actually a Jubilator. Sounds quite prehistoric!
A fine little lady!
It slowly dawned on me as I cleaned my new piston, that something didn't seem quite right. It was only when I took it back indoors and compared it with my two originals that I realised why I was feeling a little bemused. So, take a look and spot the difference.
Andy S, I expect you will read this. What do you make of it? Have I wasted my money?
Those additional slots are to help with oil cooling and when the tops come adrift you get air cooling as an extra for free.
So, because Jubilee pistons are so difficult to get hold of we can all go around in circles wasting our money until an organisation decides it might be hugely profitable, or just a nice gesture, to get some new ones made. Should I hold my breath in anticipation?
I wonder where and in how many parts, the twin of my nice new piston is. Its looking more and more as if I'll be forced to use my 36 year (at least) old pistons. As we used to say in the RAF. 'I suppose it'll do a trip'.
Engineering at its most refined!
Kevin.......Checkout BSA, Hampton, Heinkel, Honda & Jaguar who all used 60mm pistons in their vehicles and appear to be available in other sizes via JP Pistons. You might need to donate an arm and both legs.
As a far fetched alternative .....dial into AliExpress who can connect you with suppliers of 60mm, 61mm & 62mm bore pistons for 4 stroke bike engines. The prices are very low, bordering on silly but I guess you might get what you pay for.
Are the numbers below reasonably close?
Norton - 249cc OHV (Jubilee 250) Year: 1959-66,
compression ratio 8.75:1 (bore 60mm)   (in your case a bit more for +30" pistons)
compression height 1 11/16,
piston length 2  1/2 -  (flat top with valve pockets)
Pin diameter  11/16.
Robert,
Perhaps a slot was intended and seen as an improvement. More oil on the bores?
My Jubilee piston, with AE logo (Associated Engineering who owned Hepworth and Grandage in the 50's and 60's) has a slot too. Photos attached.
Definitely a story to come from our Lightweight expert on piston lubrication problems for Jubilee. I confirm from first hand experience the Navigator piston crown can separate from the rest of the piston with sufficient abuse.
And the Electra piston design is completely different and much sounder.
 I was in jest , however  in the absense of  any acceptable replacements ??.  My 99 pistons survived a seize up  with slots , but I was more than happy to fit non slotted 650 pistons . I once heard of someone selling a running bike  with a pot patch on the piston crown ,and wood pistons have appeared !.   Early 250 pistons cracked from the slots to the pins.  As Phil said there must be a solution out there.
I'm sure there is something pertinent that needs saying regarding welding up yer slot, but I'm not sure what I'd get away with.
As I don't intend doing fantastic speeds on the completed bike, and I may well be 120 years old by completion date, slotted pistons will probably hold together, so if I see another one I'll probably buy it. The one I've just bought has HEPLEX 14005 cast into the inside, and opposite that it has 4638   AM 413.
Looking at the slots, if lubrication was the purpose, I would have thought that a series of holes would have made more sense. A lot more strength left in the piston.
Phil; thanks for the piston info. Helpfully, the Hepolite box it came in has the info below. I'll contact JP Pistons and do it sitting down! I hate nasty frights!
REF. W. 14005.
2.3622" + .030"
60 m/m + .762 m/m
Whether the REF is of any use will doubtless be seen later.
And thanks everyone for all help in this.
