happy new year!
I have a late Model 50 motor, and am just getting engine assembled for it’s first run later in spring. Timing chain: it has standard cam bush, which should let small amount of oil into chain case. Any problem with greasing chain as well... standard grease? cheers, Jan.
I wouldn't bother..
... my ES2 always seems to be well lubricated. A few squirts with the oil can on assembly should be enough. Do you have the little drain union with a bit of 3/16" copper pipe to keep the drips away from the exhaust?
