Ammeter voltage
Hello my Dommie has been converted to 12v sometime in its life. Ammeter is bit scruffy and want to replace it, are they voltage sensitive see so many advertised as 6v
thanks
Amps = current (flow rate).  Voltage (pressure) is not relevant. So there's no need to change it. So you can pick whatever you like.
At 6v, the same power needs more current, so logically an ammeter with a wider range should be needed. But charging systems weren't as good in those days.
The voltage just signifies the range on the face based on the charging outputs, 6V 8-0-8 12V 12-0-12, both can be fitted to either voltage and will measure amps equally. After the first few miles the needle will be swinging so violently it won't matter, especially after the needle has dropped off,
I like it Mike. JH The numbers on the dial of the ammeter do NOT indicate Volts they are just Amps. As you say Mike the Amps are some-were here abouts! If you really want to keep a check on your charging system then an LED volt meter is a better bet. Any one who tries to sell ammeters on Voltage just shows they do not know what they are selling.
