Can any recommend where I can have a full restoration done on my 1947 model 18 fuel tank, including a re-chrome, anti-ethanol lining etc?
I wouldn't...
.. put any sort of lining in it. If you're having a full restoration done, I'd identify any leaks and have them properly welded up.
Ethanol, despite rumours, won't damage your steel tank.
Interesting statement - …
Interesting statement - "Ethanol, despite the rumours, won't damage your steel tank"
Ethanol might not, but it absorbs moisture, which then drops out and rusts the tank. Normally above the fuel level, as it creates its own moist atmosphere.
Even 'modern day' bikes suffer with steel tanks rusting, the rust gets in the fuel lines and blocks the carbs, jets filters etc. A local tuner to me is advising putting a small amount of two stroke oil in the tank to combat the problem and always keep the tank full when laid up.
Ethanol and corrosion
Colin is absolutely correct, and ethanol in petrol can certainly cause the inside of steel tanks to corrode. Although the end result is the same, I think the mechanism is such that it doesn't need moisture to 'drop' out of solution and it doesn't create a moist atmosphere inside the tank. Ethanol will strip moisture from the atmosphere (the ethanol used in petrol is anhydrous, so think of it like brake fluid: it will absorb water vapour from the atmosphere) and it will then hold the moisture in solution in the petrol. The same as sugar in tea or coffee. The presence of the moisture is enough to support corrosion - and incidentally is one of the reasons why old fuel goes 'off' after an extended period of time left in a tank. Although the corrosion might be most noticeable at the liquid surface line, it can occur anywhere where the petrol (actually petrol + a small amount of water) is in contact with the steel tank innards. The liquid surface line is where the fuel sloshes about, and where there is a lot (relatively) of moisture in the free air, but corrosion can appear anywhere including in the tank's base.
Lining a tank is one solution, but fuel additives are continually evolving and who is to say what will be compatible with the fuels of 10 years in the future. There are still two solutions:
- use ethanol-free petrol. Tomes have been written on this topic, but it should be available in SW England.
- drain the petrol tank after use, or at least don't leave petrol in there for weeks or months while it goes off. Plenty of people do this, including the NMM although partly (for obvious unfortunate reasons) for fire risk and insurance purposes.
covid-19
hello all now with COVID -19 still around all Chromers will be fully book out for the next ten weeks like quality chrome in Hull and every Chromers around in Yorkshire And I think the rest of the country will be the same and some may never reopen and have Already gone out of Business So you may have a very long wait of your hands Yours Anna J
Well...
.. modern petrol has never damaged any of my steel tanks and they haven't gone rusty inside. I wish people would stop repeating stuff they've read on the web.
WRT petrol "going off" I recently started my ES2 after it lying idle since September last year and with half a tank of petrol left in it. Started first kick and ran like a bird. I took the jets out to look at them and they were like new. The tank (as they always did) had a light coating of rust.
But waste your money and expect problems in the future with tank lining if you must. It's your bike. Although I pity any future owner.
You may like to read the posts I've put here about experimenting with petrol and carb components.
I agree with you Ian, my…
I agree with you Ian, my strimmer starts every year after a 6 month layup! However I have found that you can get green goop building up in the carb if you leave it for over a year! I only empty out my glassfibre tanks, everything else is fine.
Dan
Density
Look any water that ethanol pulls into it by hygroscopic attraction, sinks to the bottom of the tank as water is denser than fuel or ethanol, hence the Duke of Clarence story, n in a Vat of alcohol, because as you cannot swim in alcohol, it will not support your body weight, as much lighter than water.
From the surface of the fuel the more volatile parts evaporate away, hence fuel level drops slightly with no usage and the steel above the fuel level starts to corrode.
The main reported damage is at the bottom of tanks, which may have stood for a long while, this is the problem for owners of "Trailer Queen", specials, in that they are rarely started never used, (too precious), and just corrode away!
Also anywhere that has had features joined in , filler-cap hole, breather tubes, tank seams corrode first, with or without ethanol!
John
I don't believe..
.. that the ethanol "pulls in" water. It didn't in the case of my small experiment and the water I deliberately introduced stayed at the bottom well separated from the petrol above.
And it was a butt of malmsey which was a fortified wine a bit like port or sherry, not pure alcohol. I don't think there would have been room to swim....
Faeries
- Like leprechauns, and faeries, ethanol only causes problems for believers! My bike, and various petrol driven machines NEVER have their tanks drained, and often stand unused for months. 10% ethanol caused no problems in the 50's, and (as my bike is of that era) causes none now. Possibly the composition of some plastics has changed ,over the years, and may not be resistant to ethanol. However, just as unleaded petrol was predicted to destroy older engines (it didn't!), ethanol is being blamed for every unexplained fuel problem. The main cause of water in the tank is condensation, regardless of what fuel is used.
Unleaded fuel!
John Shorter, are you seriously saying unleaded fuel didn't effect some older engines?
Was you running a vehicle in 1988 & 1990s and if so what?
Quote:
“There are, however, engines which simply cannot run on unleaded fuel. These are mostly older designs, with inlet and exhaust valves directed on a cast-iron cylinder head – and the lead is needed to lubricate the valves and valve-seats. Without it, they would deteriorate through corrosion and burning. To a lesser extent, very high-compression, highly tuned engines can’t be easily weaned of leaded fuel, either.
“In addition, there are power units that need modification in order to run on unleaded. A franchised dealer will tell you whether your car can be converted economically – or refer to the relevant Department of Transport booklet or a chart produced by CLEAR (the Campaign for Lead-Free Air).
“All that needs to be done is for the ignition timing to be retarded by a few degrees, thus causing combustion to occur fractionally earlier. Most dealers will charge £10-£20. On the other hand, dealers of prestige makes might charge up to £80 for turning an ignition chip around.
“Catalyst power units, though, are a different matter; these cannot accept leaded fuel under any circumstances, and damage will result unless unleaded is used."
Autocar explained: “After what must be regarded as a period of complacency, a lot of Rover Group cars cannot take unleaded – among them all Metros bar the 1.3GS, about half the Montego range, and all Maestros and Rover 216s. However, current valve-seat development will ensure that all models built after this spring will be able to accept it, with the exception of the MG Metro Turbo and Maestro Turbo.
“Virtually all existing Fords can run on unleaded but, apart from the new 1.8-litre Sierra, they will need to be adjusted. Just the Escort RS Turbo will require leaded.
“The V12 cars will soon be factory-set for unleaded; fortunately for Land Rover, the Range Rover’s all-aluminium V8 needs no re-engineering before it can be retimed for unleaded.”
Catalytic converters are universal now, but they were almost unknown to the British public in 1989.
“Contrary to widely held opinion, an engine tuned to run on unleaded fuel and an engine with a catalyst are not the same. Have your car retuned to use unleaded, and it won’t pump lead into the atmosphere, but it will continue to emit carbon monoxide, unburned petrol hydrocarbons and nitrogen oxides (NOx) – all poisonous. These gases produce smog and contribute significantly to the acid rain that is having such a dire effect on European forests. A catalyst engine, in contrast, produces an exhaust that’s free of these pollutants.
Leaded petrol was finally banned under EU law in 2000. Lead Replacement Petrol was introduced, but was withdrawn three years later, when it was taking less than 3% of petrol sales; today, bottled lead replacement additive can be bought for classic cars.
What was all this about then?
John H
Unleaded Fuel
Yes, I was running a vehicle, in 1998, and still am. In fact I was probably driving before you were thought of. In '98 I was riding a 1950 BSA B31, '54 Dominator 88 (still am!), and a '71 Commando 750. I have owned cars dating from 1934 to the present. There is always a prophet of doom, on any subject. Quoting pseudo science, it is possible to prove anything is theoretically harmful.
Growing old is fatal, so per euthenasia should be introduced at retirement age (retrospectively, of course!).
I apologise, for joining the hijacking of this thread.
Regarding the original subject, it might be worth considering an Indian replacement, they are not all rubbish.
Unleaded?
I ran the Stag I mentioned earlier on unleaded and did around 50,000 miles on it. I checked the valve clearances religiously every thousand miles or so to start with but they never moved.
The engines that were affected by unleaded tended to be those with cast iron heads and no hardened valve seats but even those are fine as long as not enthusiastically reground.
nuleaded off topic
hello this thread start with restoration of a Norton fuel tank and not unleaded fuel witch I give a extensive report on this topic well over five years ago a no one paid any attention to the first thing to restore a tank is the get it clean inside and out, and assess any damage and repair costs yours anna j
Condensation
Anecdotal evidence is fine from people who have been driving for 120 years and have never had any problems with any fuel or fuel tanks, but there IS some science there that can't be ignored. There will always be people who have led a charmed life and haven't been affected by whatever subject comes up, but water in fuel tanks is a fact and applies to petrol and diesel tanks.
Ethanol is hygroscopic ("Hydrogen bonding causes pure ethanol to be hygroscopic to the extent that it readily absorbs water from the air.") so it can only add to any condensation/water problems - ergo, rusty fuel tanks. It is well known that diesel tanks, in particular, should be kept as full as possible so that there is less room for water vapour. This applies to petrol tanks too. Diesels are lucky enough to have water filters so it's less of a problem.
As to unleaded petrol - it is well-known that alloy heads with hardened valve seats are unlikely to get problems with seat recession - but an additive might be "belt and braces".
Soldering
Tanks can be repaired with plumber's solder. My Dad repaired the rust hole in the bottom of my 1955 tank in about 1964 an it's still there! He used Baker's Fluid as a soldering flux and probably plumber's solder from a coil.
Some time ago I reminded people that you can use plumbing solder to repair and fill steel. It was standard practice on car body panels and used at the manufacturers to cover welded seams.
Dean,
As I live in Somerset I used JBS Motorcycle Painting, who are near Yeovil and they did an excellent job. But, they don't undertake the chroming.
For the chroming I used S&T Electroplating at Yate, just north of Bristol. Their chroming plating isn't cheap, but is very good.
