Hello
Whilst checking the voltage at the battery terminals on my 650ss, I noticed that the voltage is fairly steady at approx. 14.3 V but every 10 sec or so, the reading drops to significantly less for a second then reverts back to the steady 14 V (in the region of between 8 - 1 V).
The bike is fitted with a Pazon electronic ignition and while I was out for a run a couple of days ago, I noticed a hesitancy during acceleration which I think could be due this voltage fluctuation. The bike performed much worse with the lights on but when I later checked with the meter I found the voltage fluctuation with lights on and off.
I am suspecting faulty Reg/Rec unit but was hoping for some feedback from some of the more knowledgeable members of the forum before I purchase a new unit.
thanks
David
What is the charging setup? …
Al will no doubt be here…
Al will no doubt be here shortly. But since the battery itself is the main voltage regulator the volts can only drop abruptly if a huge current is drawn, or if there is a fault inside the battery. If there's no smell of burning wires, I would suspect the battery. Where did you check the voltage? Over the terminals, or somewhere downstream?
As you say
The battery should be doing most of the regulation, so a significant change could be down to the battery trying to 'go on holiday' the Reg/Rect would be the next suspect (along with the alternator) but if either reduced the charge rate, you shouldn't see it (until the engine stops or the light go out).
So an actual drop in battery voltage long enough and low enough to up set the running would be bad connections and or a battery on the way out.
Often when riding I notice…
Often when riding I notice the ampmeter at zero but after a few minuits stop (with the lights on pilot) and the motor on slow tickover. the charge returns and once riding increases with revs ,. then settles back on zero. The battery if checked with my intelligent charger shows 14.4 v (fully charged) after a very short charge. To me this says that the voltage control (zener) is doing it job and there is more than enough charge availiable . Perhaps you are just seeing action which is normal for your bike. How does the battery behave if you charge it off the bike?.A decent battery should run for hours with no charge unless its fighting some bad connections.
Not normal
If the actual battery voltage falls significantly below its nominal 12V enough to stop the bike then the battery and/or its main connections are in serious doubt. Or actually there might be a serious short 'stealing' the power. Charging and testing the battery off the bike I wouldn't think will show up very much as the vibration and variable load might be the triggers for this behaviour. Yes a good battery say 9Ahr if reasonable well charged goes off charge, will then run the bike (no lights, normal coil ignition) for about 4hrs (50mph for 200 miles)
If you monitor the battery/running voltage down stream a bit, ie at the reg/rect or even Zener terminal, then you might get some more facts to work on, but at this point the original problem of dropped battery voltage can get nebulous. If the problem continues then please get directly in touch. aoservices.co.uk or through Roadholder.
Thanks all for your valuable…
Thanks all for your valuable feedback, it is much appreciated. I will start at the basics and check all connections again before I purchase reg/rec unit. The battery seems ok as it is definitely holding charge with all electrical loads applied. The recorded battery voltage on the multi-meter (digital) is recording values as low as 1 V varying throughout the voltage range up to 12 V +.
Also the RR is giving a very constant 13.3 Volts with lights on that it seems to be behaving correctly.
Anyway I will check again to see if I can find something more obvious, thanks again for your feedback
David
Alan didn't mention that he…
Alan didn't mention that he sells something called a Battery status monitor. Fitted one on a BSA single where I made a new electrical system. Much easier to be able to check when riding, a multimeter difficult to use riding. Found it very useful. So I'll get two more for other bikes.
What do you mean by between 8 - 1 V ?
Is it the same regardless of engine revs?
