I am thinking of fitting one of the side stands advertised in the NOC shop to my Navigator. However, from experience on other bikes I have a healthy suspicion of how secure bolt on stands are, how well they hold the bike up, whether they foul the exhaust etc, are obtrusive when folded up and limit ground clearance in left hand corners. Finally is the NOC side stand value for money? Any feed back form those who have fitted them / owned a Lightweight with one fitted would be gratefully received! Cheers Nick
Hello Nicholas, i have a…
Hi Peter, that's very…
Hi Peter, that's very helpful, I presume it bolts on using one of the frame through studs, does it require a longer stud or any other attachment bolts or does it just bolt on as it comes? Cheers Nick
Hi Nicholas yes you do need…
Hi Nicholas yes you do need a longer bolt to replace the bottom stud that goes though the frame
at the front of the engine.
Cheers Peter.
sidestands
hello My Norton Navigator Is missing its Sidestand But I will make my own as there not that hard to fabricate My 1954 model 88 has now a fine side stand fabricated by me and it will not move anywhere now as it did before I scrapped the old one and started again it took some time sorting but It's Done Now, Yours Anna J
Hello Nicholas, i have a sidestand from the NOC on my 1961 Navigator for the last twenty years and its good, for me it was worth the money and no problem in the corners.
Cheers Peter.
