I'm working on the lads Marlin which has a badly blistered laquer coat. Going to respray but removing the laquer from delicate areas is proving difficult without finishing up in the glass matt. Any ideas?.
Removing lacquer
Removes the fibre glass as…
Removes the fibre glass as well!
Cellulose Thinners
Cellulose thinners is just about the strongest solvent available - it melts many plastics and strips paint, but with careful use you could strip the top coat. What you need is a rag you can use with thinners on and another rag with some white spirit on (or your favourite drinking Meths!). You apply the thinners and quickly wipe it off! I have used it successfully on uPVC, but as they always say, test it on a piece that won't show first!
Experiment carefully - in a well-ventilated area!
Don't use solvents. Sand…
Don't use solvents. Sand away carefully with a fine wet paper. If you can't get it smooth without rubbing thru the gelcoat, stop and add more paint with a high-build etch primer. Or, if it's really bad, body filler. If the gelcoat itself is bubbling up, then knock off the loose stuff and fill.
I find that the ethanol in fuel,( petrol) damages old bike tank lacquer.pre 2 pack ,worth a try
