Cam Followers
Simple question...  Are cam followers for a Commando the same as for a 650 Dominator engine?  I have a cracked pad in the "dommie" and a set of 4 on the shelf marked up as Commando.
hello Jon - As long as your 650 Dominator engine has still got the flat followers fitted then they're the same.    Good luck, howard
