I'm thinking of fitting a pair of Armour megaphone silencers, almost straight through but for a perforated mesh.
Will rejetting the carb be essential, or will it be ok does anyone know? The carb has no air filter at present, and it'll be 50-60 mph.
Your choice, but
Different strokes for…
Different strokes for different folks! Maybe the phone zombies will hear me coming along and not just walk out in front of me, like they do at present in my works van and did frequently while riding my Indian Chieftain.
It's a real hassle extracting them from beneath the front mudguard.
There should be more than…
There should be more than enough adjustment in the carbs you have, though you don't say whether this is 750 / 850 and where you currently are with the jets currently fitted. Fit the silencers and dyno it then you can tell precisely what is happening
We dyno'd some silencers with various fillings and the straight through type were not always the loudest, like wise the quietest silencers were the most powerful, On both bikes the Premiers metered perfectly and had adjustment available if needed.
Most Dyno's are relatively cheap for an hour or so and really do tell you a lot other power and torque, get the operator to check the fueling response at gear changes. if you have issues it will show there first.
Talking of silencers,
I remember when I was a young lad, and saw a Commando at Aberfeldy campsite. What I remember is a whistle or chirping noise from the silencers and I've never forgotten it.
It sounded pretty cool to my young ears.
A number of years ago I…
A number of years ago I fitted the Armours version of the Commando peashooter silencers to my 850, they had the perforated mesh you describe.
No re-jetting required, the bike ran fine but extreme noise on open throttle under load.
I now have the more sociable standard Andover peashooters fitted which are easier on the ears!
When new my 1974 Commando Roadster had the whistle and chirping noise you talk of, the original silencers had fluted tubes and were packed with sound deadening material between the tubes and outer silencer.
The sound deadening material seemed to absorb dampness and rot the silencers from the inside out.
I think Andover offer a similar original spec silencer now, but hopefully it's without the corrosion problems
I'. Glad it wasn't just my imagination!
I'm glad other people remember the tweet from the Commando silencers. I thought for the longest time it must have been my imagination!
I remember those “whistler…
I remember those “whistler pea shooters” also They were fitted to some 750 Commandos.
... on the over-run when you…
... on the over-run when you shut the throttle - like the BSA Gold Star DBD34 "twitter" ...
I bet your neighbours are going to love you!
I cannot understand the fascination of noisy pipes - makes a ride of any distance more tiring, attracts unwanted attention and generally pisses 'non enthusiast' people off. Aren't the standard pipes noisy enough?
Just what are the positives other than a couple of bhp at max revs?
Just saying.
George
