The right hand seat retaining bolt on my Electra has a stripped thread. I ordered a seat retaining bolt SS23 71 21298 from the NOC shop. Unfortunately this is definitely not a replacement for the bolt on the bike. Does anyone know which is the correct bolt and how to get one?
Thanks,
David
Electra/Navigator/Jub standard seat bolt
Thanks, Peter. Got the…
Thanks, Peter. Got the Maintenance manual now with the part numbers. I'll look to make a replacement, as suggested.
David
Sadly they aren't available…
Sadly they aren't available in the NOC shop and strangely don't appear to be listed in my 1964 parts list - are they in the earlier parts list David? Nick
Nick, I have bought a brand…
Nick,
I have bought a brand new reprinted booklet. On the front it says Maintenance Manual and Provisional Spares List, Norton, Electra, Publication P100. It isn't dated but it does have the part numbers quoted above in it.
David
Thanks David, I was looking…
Thanks David, I was looking at the Jubilee & Navigator spares book - quite a few of the parts numbers are missing towards the rear of the frame and top of the shock absorber mounts even though they are numbered on the drawing. I will get a copy of the Electra spares list you have mentioned - a good investment! Nick
Hi David,
The bolt you have bought from the NOC Shop is for very early Jubilee. The seats on this model were secured up front by two hooks on the frame tubes and two 'Terry clips' which fitted over the large diameter part of bolts SS23 71 21298.
A passer-by could easily lift and remove the seat, exposing the tool kit too. Soon changed.
All models use the frame hooks to secure the seat at the front, with standard models having the seat rear secured between two spacers on the rear mudguard/shock top securing bolt.
I suggest you measure the length of your stripped bolt. Measure it's diameter which should be 3/8ins. Measure the length of the treaded portion to the nearest mm. Originally the thread form would have been 'British Cycle thread 26 teeth per inch'
Now you are in a good position to get a replacement.
I recommend using the part numbers from the Electra parts list. Interestingly this suggests the parts you need are stud 22572, two nuts E3224. A long bolt seems another solution.
I hope you can get a replacement. If you have any friends with tread cutting dies, then a longer stud or a longer bolt of 3/8ins diameter could be adapted.
Happy riding
