Can anyone tell me the tyre pressures for a 350 Navigator please.
Thank you
Andy James
Ask the maker of the tyres,…
Tyre pressures
Thanks for that John.
tyer presser
hello the book says 22 lb front and 23lb rear but you need that bit extra if you are heavier or are putting a heavy pack on the machine, yours anna j
Tyre Pressures
Which book? My manual (Models 88 & 99 1951-´62) says 25lbs. front, and 20lbs. rear. However, back in the 50´s, (when I rode flat out everywhere!) I ran 30lbs. front and 24 rear. I found this cured a slight weave over 80 m.p.h.
Ignore what Anna says....
... the book pressures are for the old hard tyres which were around when the bike was new. Modern tyres usually need around 28 / 32 front / rear for many bikes but as John Holmes says ask the tyre manufacturer.
Tyre pressures
Thanks to everyone who replied, I can see I have a lot to learn.
Ask the maker of the tyres, their technical dept should be able to calculate based on the bike and rider weights, ignore whats in the handbook as sidewalls are not the same and pressures are higher.
