I am soon to start on the electrics on my 1964 Navigator it will be 12 volts and with have Boyer Branson EI, I see that there's a number of options for the ignition coils ranging from the Boyer micro ones to originals coils, the question is which is best?
Steve
Dual output coil for me with…
Thanks Bob
Thanks, Bob, John and Anthony for your help it's a great help.
Steve
Single 12V dual output coil…
Single 12V dual output coil minimum 3 ohms primary resistance or two 6v coils in series each with minimum 1.5 ohms primary resistance (so 3 ohms total). Watch out for just less than 3 ohms, I had a dual coil with a 2.9 ohm resistance, On hot days the Boyer would just stop making a spark after 20 mins, a 10 min rest restored spark for another 20 mins, changed to 2 PVL 6V coils 1.7 ohms resistance and the Boyer has never missed a beat. Original 12V Lucas will give a primary resistance of 3.4 ohms 12v or 1.7 ohms 6V. If you use 2 12V coils then they must be in parallel not series and even then will not give as good a spark as 2 6V in series.
2X6V only
Do NOT use any coils in parallel (they interfere with one another it does NOT work) unless you use isolation diodes. Adding diodes adds another item to fail (and they do) with a dual output coil you get one good spark but the other spark is less good, (due to electro-thermal effect) as the poorer spark is of reverse polarity and hence not as good. Stick with the 2X6V coils and as it is a Lightweight then the original Wipac coils are recommended, these fit under the tank nicely and the HT outlet hangs down nicely. Yes they are only available second hand but the do seem to last forever. So use the original 6V coils if you have them.
Thanks Alan, I think this is…
Thanks Alan, I think this is the solution for me
Steve
Coils
Be careful of the Boyer twin coils, as I bought a brand new one from them, and only used it once. The bike would cut out and miss after it got hot. A friend of mine went to Boyer to get his own coil checked and tested, and took my one. They found it was faulty from new. They also admitted that that they get sent back some that are faulty, that they are replaced. My one they refused, as even though they could see it was new, as they said it was too old.
Use your original coils in…
Use your original coils in series they’ll work fine, mine do!
dan
Thanks, Dan I would if I had…
Thanks, Dan I would if I had them the bike is completely without electrics expept for the alternator.
Steve
Thanks Anthony that sounds…
Thanks Anthony that sounds like good advice
Steve
Dual output coil for me with wasted spark.
