Field Coil resistance
I've checked the field coil resistance on my Lucas E3L dynamo by measuring the resistance of the instrument then deducting that from the reading taken across the "F" terminal and earth. The answer is zero. I understand it should be around 3 Ohms. This may mean I have a short in the field winding. If this is the case is it repairable and who could do it?
Electrics is not my strong point!
George
When you say "the resistance of the instrument" is that with the probes connected (ie should be zero ohms)? That is normally minimal and when measuring things like field coil resistance I would just ignore it. What reading do you actually get on the field coil (your connections are correct assuming nothing else is connected eg regulator / cutout)? Aree you sure you're using the right range?
Wow - let's run thro all those, Ian
The probes gave a reading of 5.2 Ohms when connected together
When I measured the field resistance that too read 5.2 Ohms - hence 5.2 - 5.2 = 0
The instrument was set on 0 - 10 Ohms.
The dynamo was on the bench - off the bike so nothing else was connected.
George
That's an enormous internal resistance. I'd try another meter. My cheap (<£10) meter shows something like 0.1 ohms with the probes connected together.
Events moving quickly. I was misreading the meter. The Ohm scale runs in reverse. Doh! So the resistance of the meter was around 0.3 Ohms. Nevertheless I carried out a motor test only to find it was spinning in the opposite direction to the arrow on the drive casing (there is no label on the dynamo). I've reversed the leads on the brushes and it now spins in the same direction (anticlockwise) as that arrow. I'll do further tests tomorrow. Thanks for your help, Ian.
It might be a good idea to re-read page 185 of your" Classic M/c Electrics Manual"as having changed the leads around you may need to repolarize, It seems to depend on whether you have + or - earth when back on the bike.
Good point Terence. Another job for tomorrow.
BTW - for anyone else with a similar prob - Al Oz contacted me and pointed out that the arrow on the drive cover may not mean too much, it's the arrow on the dynamo itself which is important. Unfortunately mine doesn't have an arrow marked on it so it will be trial and error.
G
Closer scrutiny found an almost imperceptible arrow on the dynamo cover, A motor test showed it spinning the correct way. Yet it produces only about 1V when driven by an electric drill. Would this be commensurate with a defective field winding?
George
I've had that problem before but I think it's down to not spinning it fast enough hence not enough current to excite the field coil - especially if it's been idle for a while as the field will lose its residual magnetism. I find it useful to connect a 6 volt battery across the field windings then spin it and measure the voltage from the D terminal. Only for a short period of course........
I'll try that this afternoon, Ian, but the dynamo has not been idle in the sense that it's been running on the bike since I bought it - nearly 3 years ago - although not actually producing anything, I now realise.
G
If your dynamo has not been working all the time you have had the bike, try some basic dynamo maintenance.
Make sure the brushes are in good shape and slide freely in their mounts, and they are under some spring pressure holding them onto the commutator. Look at the commutator - is it in acceptable condition and clean? Find a clean lint free cloth and press it to the commutator and turn the engine over to clean it
A dynamo which has not been working for years will not have the residual magnetism needed to excite the field coil and generate current. Make sure the battery is holding a charge, and flash the dynamo. It's very easy to do. Remove the two leads from the dynamo. The lower terminal is for the field coil. Take a close look for a letter F Take a wire from the battery feed side and touch it a few times to the field terminal. Expect a spark. After a few touches, you should get a small blue flash. The job is done.
It's worth doing a dynamo output check. Make a short lead to connect the D and F terminals on the dynamo. Get a volt meter, put the earth probe on a good frame earth or the dynamo body, and the feed probe in one of the dynamo terminals - it does not matter which. Now start the engine. At idle, you should get around 2V, and at a fast idle, around 7 or 8 volts. Do not rev the engine..... you can damage the dynamo if you do.
Now reconnect the D and F wires to the dynamo. Do you have a charge from the dynamo?
Thanks Paul. I've done all of that. No (or very little) output. I suspect the field windings. (zero resistance so shorted somewhere).
I've ordered new windings so we'll see.
George
I'd have thought that if it motors well the field coil is in decent condition - if it's really zero resistance it wouldn't do that. I'd prefer an original to some of those available which can be of dodgy provenance.
New field windings arrived so gave the whole lot to "my man" in Bodmin who checked it all over only to find that a PO had misconnected two cables inside the dynamo which prevented any charge being produced. Apparently now all OK.
See separate thread/classified for a brand new field wiring loom for sale!
George
It's 6V, Paul. My "man in Bodmin" kindly bought it off me at the same price I paid for it. Dynamo sorted. Result! Will refit it this pm.
Fitted but nothing showing on ammeter. Voltage check (D & F linked and voltmeter put across to earth) showed 16V plus when revved.
Continuity check done on appropriate cables. All OK. The prime suspect now is the V-Reg2.
Will keep you informed - lest anyone else has a similar prob.
G
Interestingly, my ES2 dynamo was showing only a tiny voltage when spun with an electric drill when I checked it yesterday. I looked at the brushes and both were looking glazed, so I used some fine glasspaper wrapped round a bit of dowel to remove the glazing.
I then got a healthy 8 volts when spun (D and F connected).
It's not something I've previously thought about (the resistance across the commutator ie between the brushes was about 1.5 ohms with the brushes in their original state) but a nice quick and cheap fix.
Al Os very kindly checked my VReg-2 (gratis!) and all was well so I'm now investigating the wiring. Good point about the brushes, Ian, but they must be OK as I've seen the dynamo pushing out the Amps on a bench test.
Sorted! Re-fitted the VReg-2 precisely to AO's instructions and double-checked all wiring. Found a few oddities which I corrected. Started her up and all is well. Ammeter shows a charge at low revs, greater charge at higher revs and balances with main beam on. It's never done that before.
Now for those oil leaks..........
The website encountered an unexpected error. Please try again later.
