Today I finally got my barrels and heads back from the engine shop! Heads got new guides and valves, one barrel had to be sleeved and both are honed.
Now I can put my engine together. The barrels and heads were missing hwen I got the bike so I have no experience how they were fitted.
Is there a "front" and "rear" at the barrels or are they symetrically?
Any pitfalls fitting them?
Thanks for any advice!
Uli
Hi Uli, The barrel will on…
Hi Uli, Were the eBay barr…
Hi Uli, Were the eBay barrels any good?
Previously patrick_mullen…
Hi Uli,
The barrel will only fit one way -the fins on the right hand side are specially cut away to fit around the timing cover. It's ages since I had the barrel off an Navigator but I don't remember it as being a problem-the cam followers might cause a minor problem but I think a rubber band solves that (or am I thinking of something different).
Patrick.
Good idea about the bands, I was scratching my head over that. I was going to use grease, but bands are better.
Andrew
Previously Dan Field wrote…
Dan, the engine shop did a good job with sleeving and honing the cracked barrels. So I stick with them. They informed me yesterday so I picked them up this morning.
The recently purchased barrels via Ebay are for a Norton Electra .
I would have been in need of new pistons and heads plus sandblasting, reboring etc.
They are surplus now.They?re rusted but without broken fins. I didn?t try yet if they fit on the Navigator engine.
Hi Uli,
Patrick.
