Hello All,
I have asked variantions on these questions before I realise but. I have a filter plate (bought at an autojumble but by the looks of it the same as the one on the spares site). It has 10mm spigots and while I have extracted these from similar plates on other bikes (as most British bike oil pipe is 5/16 ID) thess kook like permenant fixtures.
I am thinking of sleeving the stub taking oil back to the tank and the pipe from the engine to 10mm to get round this. I have done it beore on a Triumph with a Mogo rotary pup and all seems OK.
Has anyone done this on a lightweight?
Some one has been kind enough to send me a link to a firm selling long handled tapes--I can get these in 8 or 10 mmm OD and was thinking of leaving the feed iose 8mm 5/16 ( if you so this these are parts of the system that have to remain the old size). The feed strainer that screww in the tank has a bulge in it making loctiting reamed coiooper pip over the existing pipe more difficult.
Feked, the supplier of the tap mention people riging up an ignition cutout--has anyone done this? I did the same on a BSA B40 25 years ago but was able to get micro switches from work then.
Any advice greatefully received
JPA
Not sure what you mean by…
Previously Dan Field wrote…
Previously Dan Field wrote:
Not sure what you mean by âfilter plateâ but I havenât ever had a problem with wet sumping on a lightweight.
Dan
Hello Dan,
What I mean by a filterplate--the alloy housing a car type spin on filter screws on to. It has stubs in and out.
JPA
Ah, now I understand, I ha…
Ah, now I understand, I have a filter on my jubilee, mounted behind the centre frame section above the centre stand, I didnât measure the pipe diameter, but found a length that fitted both ends and jubilee clipped it up, job done!
You were lucky there Dan,
I have one of these on each of my Triumphs and I believe they werea 2cv part orignally. They both have (had in one case) 10mm OD stubs whereas 5/16s (8mm is the norm with British bikes some have a larger feed than a return some BSA singles for example.
I extracted the stubs from one filter plate but these look like permenant fixtures. I only ask as I do not know much about Norton oil pumps--the other bikes bar the BSA have Morgo pumps and capacity to spare.
Hi John, Itâs fitted on t…
Hi John, Itâs fitted on the return, so donât see a problem?
There probably is not one--I just wondered if anyone else had encountered it--most filter plates have different size stubs that most british bike engines' oil pipes--something usually has to be changed--on previous ones I have been able to remove the stubs and fit corrctly sized ones--this on has stubs that seem cast in. In some, usually hydralic, appications pipe size matters--but, as brit bike return side pumps are essentially pumping bubbles under relatively high pressure it probably does not not matter much.
JPA
I fitted a filter plate to…
I fitted a filter plate to my Dominator, mounted behind the gearbox. I used a tatty original pipe assembly and cut the crimp fittings off the return feed, so that I could have the pipe unions and nuts. Rubber hose simply went straight onto the fittings and I fitted hose clamps. At a later point I may get it properly crimped so that it is permanent
With such a small motor, you don't need to have the huge capacity of the full-size filter. There may be a smaller oil filter arrangement which would be more compact, and have the 8mm hose fittings you would prefer
Good point, Morgo do a sma…
Good point, Morgo do a small one. The link is on my thread on filters for singles, this onehttp://www.morgo.co.uk/15-morgo-oil-filter-kit.
Dan
