Hi i,ve an electra but not sure where the brake light switch should be mounted navigator should be the same .photo would be brilliant ,thanks Martin
On the early Navigator the…
Previously patrick_mullen…
On the early Navigator the Wipac brake light switch is attached to the rear footrest via a simple bracket. If you are using a later universal type of switch - easy and cheap to obtain - then you simply make a bracket to attach to the footrest mounting bolt. The Electra is probably similar.
Patrick
thanks for the reply
Here you see my selfmade b…
Patrick
