Just received my Pazon 12volt Sure-Fire ignition system for the Jubilee.
Looks a easy fit. Where I might struggle is understanding the timing instructions. Do I find top dead centre, turn the engine back 24 before top dead centre and thats the timing done.
After fitting the unit I can strobe it by fitting a pointer on the housing screw hole and the mark the router. When I mark router do I mark it for top dead centre or 24 before top dead centre.
John.
Find TDC, turn engine back…
Thanks Kevin. I dont think…
Thanks Kevin.
I dont think there is a LED on mine. Its a (product code) PA2L
John, The ignition timing…
John, The ignition timing on the Jubilee is 32 BTDC not 24, Attached page from manual.
Dave.
technical-data-jpg
Previously john_dunn1 wrot…
Previously john_dunn1 wrote:
Thanks Kevin.
Ah, sorry about that! Mine is the PDMT1 SmartFire. I think the principle will be similar though.
Kevin
When setting the timing, i…
When setting the timing, isn't it regarded as good practice to turn the engine back beyond the 24 (or 32) mark, then move it forward to the chosen mark so as to take up any slop in the gears?
Previously howard_thompson…
Yes. I was always taught to do this on BMC A and B series engines. But these engines do have timing chains.
Could I suggest to John that he read the instructions from Pazon- if you set the timing to 32 degrees static does the Pazon then some how automatically retard the timing for starting ?. 32 degrees is full advance and too much advance could wreck an engine. Sounds odd to me but I am not familiar with aftermarket electronic ignitions.
Patrick
Previously patrick_mullen…
Patrick
Hi Patrick,
Yes, you do time the Pazon at fully advanced. This is when the LED comes on. When running, it sorts itself out.
Thanks Tony for that confi…
Thanks Tony for that confirmation.
I looked up the Pazon website last night and I was genuinely impressed with the detailed technical information that it supplied. There is even a graph showing the spark advance which unquestionably shows that it does retard the timing for starting/slow running and advances the timing as required for higher engine speeds. It also gives some useful information on coils to use. All told the website does gave the impression of a well designed/researched quality item; quite surprising in fact for such a low volume machine.
Their website gives the same timing for the Jubilee/ Navigator/Electra -all at 32 degrees-which does make sense to me even though most traditional sources seem to quote 24 for the Navigator.
Patrick
Just another quick questio…
Just another quick question. Wiring the Pazon into the circuit prevents no problem. Just want to make sure Im timing it right. Find top the dead centre turn the engine back 32 degrees before top dead centre. Is that more or less job done other than setting up the Pazon and then strobing it. Do the red timing remarks line up through the clockwise hole.
John
Patrick
If you follow this website timing for the navigator as 32degrees and at a later date damage occurs, who you going to blame? I have set the timing on my navigator at 24` and tweeked it a little bit nudging up slightly the advance. I have recently been on a long sustained run up to speed limit (occassionally),no problem. On the way back (after150miles) I topped the tank with 10 ltrs of 98 unleaded from a supermarket service station and continued my journey,the bike then started to struggle.I got back and flushed my tank with the fuel I was using usually, and everything went fine again. My point is ,even if you set your timing to original manufactorers reccommendations modern fuels and inconsistances have an effect on ignition timing and I thought all fuels were the same??
GRAHAM
Find TDC, turn engine back to 24 BTDC, turn the Pazon cct board until the LED just comes on, then turn the board back until it just goes out. Job done.
I marked my rotor for TDC only. I cut a hole in the primary chaincase and marked that for (in my case, 650SS) TDC and also 28 BTDC to allow checking with a strobe. Hole is then plugged with a large grommet.
Good luck.
Kevin
