I have been out in the garage recently and am quite pleased with my version of a crankcase drain plug. It is a brass fitting as used by plumbers for connecting up to a plastic water storage tank plus a standard brass stopend. It is fitted to the early type sump filter plate from the 1959 Jubilee. So far it has passed it's 'leak test'.
Patrick
p2040054-jpg
And another pic showing th…
Previously patrick_mullen…
And another pic showing the inside fitting
Nice idea Patrick, do you think a magnet fixed inside it might be an added bonus. A nice improvement and practical solution to wet sumping.
Andrew
Personally im thinking of…
Personally im thinking of making a sump plate from a piece of cast iron in the hope that it doesnt flex and leak! ð
Previously Andrew Wibmer w…
Andrew
Andrew, now that is a good idea and I have some useful magnets at the back of the bench as well. Time for the MK11 model.
Dan, I think current paper gaskets are the problem although they probably work fairly well with the later alloy plate. I didn't realise until very recently that the original gasket was made from thick cork which seems to work well; the four nuts only need to be a little better than finger tight and no leaks,
Patrick.
Patrick, Well that save yo…
Patrick, Well that save you a few quid.
The NOC shop lists a sump plate with magnetic drain plug at £42.50 ex vat and shipping so your mod is a bargain.
I might try that myself but I have some 10mm connectors in alloy that I can use.
Dennis
p2040052-jpg
