dominator fuel tank
Does anyone have experience with the Model 99 fuel tanks sold by Royal Enfield out of India?
Not quite but I purchased a set of mudguards for the 99 from them, they were well made and fit.
I purchased a tank from them, ( for a '54 Dominator ) and do not regret it. The quality is excellent, and they are prepared to finish to your specifications. There was a very slight problem with the front of the tank sitting on the frame tubes, but relocating the mounting rubbers slightly solved this. The only thing I would suggest is that, if you require an exact colour match, order an unpainted tank. Contact Arpit Gupta, by email, and tell him your exact requirements. Delivery was free, and, in Spain, there was no import duty ( you probably won't be so lucky in the U.K.!).
