After finding a couple of my 12v sealed batteries dried out,dead and sulphated I'm thinking that an earlier intervention with some top up water may have saved them. Now looking at my 6v Burlen which has sealed ports under the name strip. Has anyone got into one of these?.
I don't think you can do…
My Burlen batteries are ye…
My Burlen batteries are years old and still working well - unlike other reputable sealed batteries which seldom seem to exceed 18 months.
First question is "does th…
First question is "does the bike have an electronic regulator"?
The original lighting system used a complicated light switch which switched alternator coils in an attempt to match output to load.
Headlamp = 3 pairs of coils in parallel.
Sidelight = one pair of coils only
No Lights = one pair of coils only but with the other two pairs shorted out to reduce the output.
At the end of the day it was crude. If more power was produced than was drawn then the only place the surplus power could go was in electrolysing the battery acid - spitting it into hydrogen and oxygen - heating the battery in the process. This is why you were supposed to top up your battery with distilled water at intervals. When 12V was introduced there was a lot too much power at least some of the time and the Zener diode was introduced. Basically some surplus power is dissipated in the form of heat but it is a rather basic device and some overcharging is likely to occur. A sealed battery won't take that punishment. It will last very well provided it is never overcharged so should not be fitted to any bike without an electronic regulator to prevent overcharging.
As it happens the bike wit…
As it happens the bike with the Burlen does have an electronic regulator which replaces the crude 3 brush Millers dynamo system in use in 1936. The sealed cell batteries I had to scrap were 12v units powering a mobility scooter which lasted a couple of years and then died completely. Looking inside I found them to be bone dry, making me wonder if a little maintenance would have extended the life.
Hi Robert, yes, I've got…
Hi Robert, yes, I've got a sealed 6V Burlen battery AND an electronic regulator. It's a totally reliable set up, never had a problem and the battery seems to keep its charge remarkably well. It's been on the bike since its rebuild eight or nine years ago, the solid state regulator added for seven of those years- the old Lucas one went bonkers and melted itself, like they all do eventually. Would certainly recommend, but wouldn't try surgery on it.
I don't think you can do anything with them. But I may be wrong....
I've never had a problem with sealed batteries (other than them suddenly dying on me).
