Having ordered new clutch plates for my 1949 500T I now find that they are a bad fit.
The new friction plate with outer tangs is 150mm (not including the tangs)
making them 2mm too big. The old plates are 148mm
The tang size is OK.
The steel plate (inner tangs) fits the basket but the tangs are too big on the centre.
Before I start with a file has anyone had trouble with clutch plates. Or any ideas.
I am unable to get into the online parts list here at NOC is there a problem with the site.
I would buy plates from our own site if I could access it.
Thanks Robert
Can't help with the sizes…
Previously ian_soady wrote…
Previously ian_soady wrote:
Can't help with the sizes as I've just screwed mine back together and would prefer not to strip it again. I'm not even convinced mine is the right clutch....
but the shop error is probably your browser cookies. It happens frequently to me. If you clear all the norton owners club cookies it should work....
Thanks Ian. Got the online store problem sorted as you suggested.
