I've bought a timing cover from fleabay ostensibly for an ES2 but regrettably it doesn't quite fit. Everything is fine apart from the two fixing holes inside the timing chain compartment which are at different centres to the original.
Inside the unit is stamped the ref. "F911" and elsewhere "WM". Mine has stamped "N304"
Can any one shed any light on which machine the replcement unit is from or perhaps the year?
I may have to put it back on fleabay so it would be useful to know to which machines it can be fitted.
Thanks guys.
George
Hi George - if need be wel…
How much is each hole off…
How much is each hole off by?
Thanks guys. I'll check t…
Thanks guys. I'll check the dimensions tomorrow but would still be interested in the significance of the numbers.
George
Previously George Phillips…
George
A picture would replace a thousand words George. You may be luckyand have something a bit more desireable.
When in corrrect physical position does either hole align?
Is there a Nortonscript, angled or parallel to the long sides? Any rib ?
With respect to numbers the cast in ones are more important thanthe builders stamped in ones when trying to determine origin.
The cast-in number is 1302…
The cast-in number is 13022 and below that WM. As far as I can tell these are on both units.
I'll try and organise a pic.
George
Hi George. I have checked…
Hi George.
I have checked my 1948 Model 18 engine. The timing cove has the cast of WM1596 and also 13822 (maybe your 0 is indistinct and should read as 8). It also has stamped A278. The timing side crankcase has the cast WM1595 and the stamp A278. I take these to indicate that the WM numbers identify the parts and the stamped numbers reference a specific engine, probably in this case to match a pair that had the camshaft bushes line reamed. I aquired a spare timing cover and that has the same casting marks but is stamped B578, therefore from a different matched pair of timing cover and timing side crankcase. The mounting holes of both timing covers match the crankcase I have.
What is the WM cast number of your original timing cover and that of your new one? Is it in the series linking it to your timing side crankcase?
Regards Nick
Definitely cast WM13022, N…
Definitely cast WM13022, Nick, on the original and the "new" (which I've now returned).The stamped numbers are N304 on my original and F911 on the returned unit.George
I can't check the casing…
I can't check the casing now as it's with the engineering firm, Nick, but looking in detail at the pic I took I see that the stamped number is WM1382 with the hole for the retain bolt passing though any following digit.
George
Sorry the information coul…
Sorry the information could not be of help to possibly identify where the problem lay with the timing cover you bought. At least you say you have returned the unit. Hope the engineering firm can sort it out for you. Best of luck, Nick
Hello WM use to stand for…
Hello WM use to stand for war ministry if I am not right I stand Corrected, But I will tell you why I have a Ex RAF, Norman SC Stationary Engine for fuel pump use, and I have rebuilt It and its is Marked WM 201 batch number 3002 built 1942 now WM is for War Ministry yours Anna J
Any thoughts on the "N" an…
Any thoughts on the "N" and "F" prefixes, Anna?
Hi George - if need be weld up the holes and bore new ones perhaps ? -
Richard
